lazflyn wrote:...Then after it's been on for a bit, I press the "OK" button, then let it sit for a bit (like 10 min). After that I shut it off. I guess Rob is saying it will last a year if left on continuously? Where does it say it will last that long?...
I recommend turning it on and leaving it on during your trip so it will always have a current GPS position. Here is the info from SPOTs website about battery life:
Battery Life
Includes 2 AA 1.5V lithium batteries; under normal usage a full battery charge should meet or exceed the following
* Power on, unused: Approx. 1 year
* SPOTcasting tracking mode: Approx. 14 days
* 9-1-1 mode: Up to 7 consecutive days
* SPOTcheck OK/√: 1900 messages
When you press the OK button your SPOT tries three times over 15 minutes to send the message. The server software edits out any duplicate messages so your recipient only gets one. If you turn the SPOT off before this 15 minute period is up you will reduce the chance of a message getting through. You will know its finished when the "OK check" light stops blinking and just the "On/Off" light is blinking.
