Hammer wrote:Spin training is good: Not stalling the wing is INFINITELY better.
Spin training is great fun and well worth the time and money even if only for the thrill, but the best time to do it is in the first week of flight school. If I'd done a day of spin training before I started my private ticket all those stalls would have been a lot more educational and a lot less stressful than they were.
In a hour you can recover spins to a fairly close compass heading, and the only problem with doing a 14-turn spin is the time to climb back up and do it again. There is really nothing to them providing you have a suitable aircraft and enough sky below you. I find them strangely relaxing...sort of like being on a swing.
But I really don't see how spin recovery training, fun as it is, increases pilot safety in any meaningful way unless it gives you the confidence to go out and practice aggressive stalls (not spins) on a more regular basis. Most people have no reason to fly close to a stall unless they're also close to the ground, and if you're close enough to the ground to be flying at an airspeed where a stall is possible, you're much too close to recover from a spin.
While I have no intention of finding out, I'm pretty sure that my airplane with a load in it won't come out of a spin with anything like the control inputs and alacrity I've experienced in spin training, if at all. With no confidence that I can recover from a spin while hauling a load, I don't practice stalls in that configuration, either. I could go out and practice perfectly coordinated straight-ahead stalls with a load, but that's not going to teach me much of value. It's the stalls in a turn, maybe a balls' width out of coordination that get us. My unloaded stall training still has some value, but I really don't know how my airplane will react to a uncoordinated stall while hauling my normal load, and I don't anticipate finding out, regardless of my altitude or prior spin training.
In other words, spin training doesn't make you spin-proof, and if you've inadvertently stalled the wing close to the ground, recovery might not be possible. So don't do it!
I was not advocating for "spin training", though it's not a bad idea.
What I WAS advocating for, and what Rich Stowell teaches, is "Upset Recovery training" or in Rich Stowell's lexicon, "Emergency Manuever Training or EMT".
AG operators do a lot of turning, but typically these turns are ~ 180 degrees or so. And the AG pilot typically isn't focused on something on the ground....other than as necessary to position for the next swath. That video is right on for that world.
But circling flight can take on some additional dimensions, and add significantly to the risk factor of low level flight.
If you really believe you will always precisely control your aircraft while looking at things on the ground, you MAY be fooling yourself. I've lost some pilot friends who were VERY experienced pilots in this game. And the scenario is generally the same.....circling flight, looking at something on the ground.
My theory is that many of these accidents are the result of a combination of aerodynamic factors, one of which is self induced wing tip vortices. Combine a vortex encounter with a high AOA and slightly different AOA on each wing, and you have a recipe for a stall break that will be abrupt and totally without warning.
That's what Rich's program is about, as well as turning safe, which is just as important and which the turn safe video does a good job of explaining.
That said, you can learn a lot about theory from a video, but to quote Wilbut Wright: "If you are looking for perfect safety, you will do well to sit on a fence and watch the birds; but if you really wish to learn, you must mount a machine and become acquainted with its tricks by actual trial."
Good advice.
