Flyer,
I think you are missing the point regarding the definition of the term "Flight Testing" when it comes to certification.
I have no doubt that Micro did "flight testing" of their VG's on a Maule, and every airplane that they make VG kits for. The point is, the "flight testing" they are required by the FAA to do essentially only requires that they demonstrate that the modification does not create any ADVERSE flight characteristics. Going a little slower is perhaps undesireable, but certainly not an "adverse" flight characteristic by FAA definition. So, they do fly the things, both to demonstrate no adverse flight characteristics, and to determine what appears to be an optimum location for the VG's.
Now, consider the Robertson STOL mods. Robertson went through complete flight test, including all aspects of the flight testing protocol for modifying the airplane. They issue a flight manual supplement for the modified aircraft which specifies significantly lower stall speeds. THOSE speeds are now part of the airplane's operating limitations, and have been documented using a calibrated test boom, etc, and during a full flight test program.
Take a look at ANY of the modern "STOL" kits (Bush, Sportsman, Micro Aero, BLR, etc) flight manual supplements. When it comes to airspeeds, they are either silent, or simply say that the kit creates no adverse flight characteristics (or words to that effect). They do not provide lower stall speeds IN THE FLIGHT MANUAL SUPPLEMENT than stock. If they did (as Robertson did) they would have to complete full flight testing that proved that reduction in stall speed.
Now, as far as advertising goes--you can advertise anything you want, and you don't have to prove it or document the proof that the information is accurate. It's called "Buyer Beware". So, next time one of these outfits tells you their kit will reduce the stall speed by 4 knots or whatever, ask them to provide flight test data to support that claim....
But, also realize that, just because it hasn't been thoroughly flight tested, doesn't mean it DOESN'T reduce the stall speed either. Point is, there's no documented proof, based on very controlled and corrected flight test data.
The BLR kits (the BLR stc for the Cub is now owned by Cub Crafters) were designed by a fellow named Bob DeRusche (sp). He and Charles White were partners early on in the development of VG kits, but split over differences of opinion. I believe De Rusche was a flight test engineer for Robertson at one point.
In any case, they have taken slightly different approaches to the application of VG kits. Micro appears to take the approach that ANY wing will benefit from a set of VG's. BLR has stuck to more rigorous flight testing, and modifies airplanes that they seem to feel benefit MORE from VG's. Frankly, I don't know which is more accurate, but I'd stand by my statement that different airplane designs respond differently to the application of VGs, and I think the discussions here would suggest the same.
As always, your mileage may vary.
