This is from a 56 180 that I ferried out of AK this past spring, and am now doing a pretty extensive annual on. I did a thorough inspection with a bore scope, but it wasn't until I had everything apart that I was able to see just how bad it was.
It seems that these cracks are not products of age and time, as deficits are being found in different age air frames and different flight missions.
The bottom line is make sure you are having a real good look... If your mechanic is telling you you can comply with the AD w/out removing the stabs, perhaps its time to find another mechanic.
