Essentially the yellow loop anchors the tail wheel to the ground anchor. The tent stake acts as a release pin, and the grey line runs up to the cockpit where it both pulls the pin to unfasten the yellow loop, and retrieves the rig.
This is the basis of the unit...real, real simple.
Connection to the airplane is made by simply having the loop run around the tail spring above the tire, or through a ring attached to the tail spring like the Cessna Birddog sports. It’ll work either way, though if it’s just looped over the tire care must be taken to ensure the airplane doesn’t roll backwards and free the tire from the loop. Note that rigged properly the pin will not touch either the ground anchor or the tail spring.
Here's the release pin attached to the grey pull cord. In this example the airplane would be to the right.
Any suitable cordage will work. This example is made out of dyneema line which is ridiculously strong. The yellow cord is rated to 900 pounds, the grey line to 500 pounds. I don’t know what the yellow loop would break at with the aluminum tent stake acting as a pin, but I’d bet it's more than any aircraft spec’d without a starter motor can produce at full throttle. Of course larger line could also be used.
Dyneema line is also very slippery, making it a good candidate for sliding around tail springs and ground anchors. The rig releases easily under as much stress as I can generate by hand, but I haven’t tried it on a airplane yet. The only thing I can see being a potential issue is how the cord interacts with the tail spring.
