Do NOT use those springs on a 170. When (if) they reach their limit, they hit a hard stop. That’s how you break things.
First, look at the angle of the tailwheel as it rests…..with some weight in the plane.
My guess is you have an original 170 tail spring, which generally suck. Go to Univair or Spruce and order a MAIN leaf for an L-19. It’ll be thicker than your main leaf. Replace the main leaf in your stack with that L-19 main leaf. You’ll have to remove the shortest leaf in your stack to make it fit.
Then, if you don’t already have one, replace your tailwheel steering arm with a 3214T “Bent steering arm” from Airframes AK.
The stock 170 spring isn’t stiff enough. The L-19 main leaf gives the stack enough stiffness.
My mechanic called all this a minor alteration. Never had another shimmy.
