PatrolGuy,
I'm thinking you were at Rexberg maybe....it is quite a bit shorter then this strip! There are a few warbirds there, and friendly people.
Good link as to what it is all about. Nice floor for sure, I expected no less! A flying buddy of mine (and also another crane operator) has been spraying urathane foam up there.
He would have been better off going with flat plate solar thermal panels if he was trying to heat the floor, doing it with the type pictured is needlessly complex, and actually less efficent at the very low tempertures used for radiant floor heating. I saw them all out on the ground, not a good sign! Looking at the picture, you can see them all stacked on the ground at the right side of the hangar. As one who has heated his hangars with solar thermal for 30 years I'd have a few comments on the way his system was set up. Needlessly complex, and the fact that they are on the ground speaks volumes, problems obviously, too bad. Damn I wish I got have got in on that!
My big solar job is south a ways in the same valley, in the low rent neighborhood. No asphalt either. But at least I can land right at the job site, this day I was working in the battery shed on the left, wrapping up the auto start feature of the backup generator. I got sidetracked on the way there, usually a 1 hour flight, it took me 4. At the end of the day, by the time I got home it was 5.3 hrs of flying and 2.5 hrs of work, just right
