hotrod150 wrote:182 STOL driver wrote:.......I'd send the case out to be welded and up grade -- I get the Norland STC and go to 260 hp. Bigger engines (PPonk-Texas airplanes etc.) suck more gas ......
Is the Norland STC'd engine still 470 cubic inches? How does it get the extra HP? Seems like if it was higher compression that would eliminate mogas as an option.
I believe 91 octane is still okay with the Norland, though stated otherwise. Supposedly the cheapest engine upgrade and best bang for the buck but as posted above, not well known.
From Norland:
Attached is the basic information needed to build up a IO-470 for use per our STC.
1. Dear Sir or Madam:
Thank you for your inquiry about the 260 hp engine conversion for your Cessna 180 or 182.
Your O-470 engine must be exchanged for an IO-470 series, which is then modified according to our STC. The cost for an IO-470 engine "0" time exchange, for your old O-470 is approximately $1500.00 - $2500.00 more than overhauling the O-470. We can assist you with quotes on engines.
Our STC is for the use of the IO-470-D,-E,-F,-H,-M,-N or -S engine in a modified condition, that is, with the fuel injection system removed and replaced by the carburetion system that is original equipment on the O- 470 engine. The IO-470 engine is a high compression version of your original O-470 Continental, requiring 100LL fuel. There is no other change to the fuel system, engine mount, exhaust or cowls. We do not recommend the use of a 3-blade propeller because of the weight increase.
The propellers currently on the Eligibility List are as follows: McCauley D2A34C49, D2A34C58, 2A34C66, and D2A36C33. A complete Eligibility List of engine and propeller combinations is included when you purchase the STC.
The IO-470 series engine produces 260 hp at 2625 rpm. Changing this injected engine to a carbureted engine has not reduced its power. The less efficient carburetor uses slightly more fuel at maximum power settings compared to the fuel-injected version. If you fly at your normal cruise speed you will use less fuel with our modified IO-470 than with your original engine.
The figures that follow are from Cessna Range Charts. Fuel flows are taken at 2500 ft., standard day conditions. The fuel flows for each engine are almost identical when they are run at the same power settings. e.g. at 23" and 2300 rpm the difference is .3 US gallons per hour, or just over 1 liter per hour more fuel is used in the 230 hp O-470. At this particular power setting, the O-470 is at 71% or 164 hp. The modified IO-470 at 23" and 2300 rpm is at 65% or 170 hp. A Cessna 180 stock engine will cruise at 154TAS, or at 158TAS with the IO-470, on wheels.
I feel that the 260 hp engine is the very best value in power upgrades. You have all the equipment you need already and eliminating the fuel injection system means no hot start problems.
The STC alone is $2000. Your A & P can easily accomplish our STC.
I hope I have answered some of your questions. Please call 1-888-244-1112 if you require more information.
Sincerely
Chris Bullerdick President/Chief Engineer
