As I'm snail pacing myself towards a kit order – I have the plans – I spend more hours than I care to admit on contemplating different alternatives when it comes to everything from tail gear to avionics and, engines.
I will use the Patrol for float operations, for sightseeing, for travel and for learning backcountry flying. I want to be able to go to the low hundreds for cruise and I'll operate at "airports" up to say about 6000 feet.
The future availability of 100LL is a major concern, I'm in Swedenn, and hence I want to be able to run it on mogas (with a 5 per cent ethanol blend).
I've looked at, and discarded, auto conversions. Now I lean towards Lycoming clones, more specifically the R409 from Titan (ECI) with electronic fuel injection and ignition from EFII.
I've talked to EFII and the the dual ECU EFII is a "double everything" for redundancy purposes. And it's ok to use with ethanol blended mogas.
I've also talked to Titan and the R409, with Titans latest cylinder/piston combo, is also good to go on as low as 90 octane (RON+MON)/2 ethanol blend mogas. And it's making 230 hp weighing in at about 285 pounds.
Now, the Patrol is "approved" for engines up to 210 hp but even if I can't get a statement from Bearhawk that 230 is ok I can "derate" the power via limiting either rpm and/or manifold pressure until I'm at an altitude where I can go WOT. That would give me a flat rated power of 210 hp up to almost 4000 feet if I remember the formula correctly (assuming ISA of course). A huge benefit, especially on floats. In addition to this, being able to operate at reduced rpm's during take off will reduce noise levels substantially. I routinely did this when taxi-operating a C206 on floats (27/27 really keeps noise and CHT down compared to WOT/2850).
About noise. I'm really keen on getting the Patrol as quiet as possible. I'm looking into possible (light) muffler solutions but I've also initiated contact with Hartzell about their Trailblazer prop, explaining my intended use of the plane and that I'm willing to sacrifice some cruise performance for STOL capability. There's one being tested on a 180 hp Patrol but I'm most interested in a 3-blade version, it should be quieter thanks to reduced tip speed. So far they haven't tried the 3-blade on a 4-cyl but they will.
I have a carbon MT on my Skybolt and I really like the quick response a light prop has.
Please fire away with opinions! Do you have a setup that you recommend? What prop should I use? Is 230 hp too much (can you have too much?)?
