Backcountry Pilot • Throttle surging
Throttle surging
4 postsPage 1 of 1
Throttle surging
Hello,
On my new to me 69 206 my throttle surges forward when running. When running, especially with airflow, if I don’t lock the vernier down it surges forward at least 1000 RPM. It feels like a spring is pulling the throttle forward but when the engine is off it stays in the same position, guessing this is something to do with airflow on a loose butterfly valve but wanted ask for opinions.
Thanks,
Mike
AZ Flyer offline
Aircraft: Cessna 206
Re: Throttle surging
I have heard of and seen springs installed on throttle arms, so that in the event of a throttle cable failure it fails at full power so that the ship doesn’t become a glider. The symptoms sound like they could be related to such an arrangement.
Scolopax offline
Good point about the spring, but when the airplane is off there seems to be no pressure on the throttle, it only seems happens when there is airflow.
AZ Flyer offline
AZ Flyer wrote:Good point about the spring, but when the airplane is off there seems to be no pressure on the throttle, it only seems happens when there is airflow.
It seems like airflow should produce a Force couple about the shaft in the throttle-body, resulting in a moment that would act on the throttle valve in the same direction as the spring. I would look to see if there is a spring installed.
Scolopax offline
4 postsPage 1 of 1
