Squash wrote:Oh, wanted to mention that you may want to throw some duckbill anchors in your stash if you should ever end up in a bad windstorm. When you absolutely need help holding the plane, there is no portable system that will perform better. You just can't easily take them with you once installed. They are sort of the transition tiedowns between permanent and portable.
). If he'd treated me better, I would have retied his airplane myself, but I left it alone. Well, the wind did come up. When I left the FBO that afternoon, the 170 was rocking in the wind, with the chains banging. The next morning I was taking a charter, so I was out there early. The 170 was still tied down, but with a bent left wing and strut."
denalipilot wrote:What's the group opinion of the heavy steel cables laid on the ground that a whole row of aircraft can tie to? In my experience they have a lot of these in the prairie provinces of Canada. Most that I've seen are only anchored to the earth at very wide intervals, like every 50 or 100 yards, or more.
Maybe I'm doing something wrong, but when you pull any tension at all on the airplane tiedown ropes, the cable tends to lift up away from the ground and contact the tires, gear legs, brake lines, etc.
Seems like a clever idea, but would work better if the cable was staked to the earth every fifteen feet or so.
-DP
-DP
GumpAir wrote:Ask Coyote Ugly about those cables and Furnace Creek in Death Valley.... Not fun.
dogpilot wrote:Chains are excellent, just really heavy, wouldn't want to carry them around. We always chained aircraft down on the deck of the aircraft carrier. There the ground moves, in addition to the air moving, not to mention the occasional wave of water breaking over your aircraft. Used 18 chains to secure my 205 million dollar 52,000 lb E-2C to the deck every day.
Zzz wrote:dogpilot wrote:Chains are excellent, just really heavy, wouldn't want to carry them around. We always chained aircraft down on the deck of the aircraft carrier. There the ground moves, in addition to the air moving, not to mention the occasional wave of water breaking over your aircraft. Used 18 chains to secure my 205 million dollar 52,000 lb E-2C to the deck every day.
And you flew it after that?
