probably should have gone around on this one........
MAU MAU wrote:The German may have encounter a 'sinker' when he transitioned from flying over the relatively cool water to the heat soaked beach.
rw2 wrote:MAU MAU wrote:The German may have encounter a 'sinker' when he transitioned from flying over the relatively cool water to the heat soaked beach.
Wouldn't the heated air over the beach be rising?
MAU MAU wrote:rw2 wrote:MAU MAU wrote:The German may have encounter a 'sinker' when he transitioned from flying over the relatively cool water to the heat soaked beach.
The superheated rising air is less dense therefore affording less lift. (Density Altitude)
It is especially prevalent during the summertime where extra speed must be held in anticipation of the inevitable sinker over the immensely hot black runway. Without that extra speed, I have seen aircraft come down like a rock resulting in a hard landing requiring a maintenance inspection on an airliner.
MAU MAU wrote:What part of this are you having trouble understanding?
As an example, under a given weight in your aircraft, will you be airborne sooner on a 40* F day or a 90* F day?
When you are landing over cooler surfaces (such as water) at airports like JFK, LGA, or St Martin in the summertime, you will get sinkers. Period.
And if you do have a hard landing in an airliner, you are required to make a log book entry, and a maintenance inspection is required prior to further flight.
Zzz wrote:That said, in the world of light GA aircraft, encountering a stable hot air mass that isn't bubbling upward is the rare condition.
