http://www.nasa.gov/topics/solarsystem/ ... lipse.html
Skystrider wrote:How many know which lasts longer: a solar eclipse or a lunar eclipse. Reason?
kevbert wrote:Skystrider wrote:How many know which lasts longer: a solar eclipse or a lunar eclipse. Reason?
That's a false dichotomy. You could get a job writing survey questions for the government!
Usually, lunar eclipses are longer than solar eclipses, but sometimes it's the other way around. Each eclipse, whether solar or lunar, has a unique time of duration. The reason is that the moon's orbit is not in the same plane as the earth's equator, and the moon's orbit is also not in the same plane as the earth's orbit around the sun. You could have a lunar eclipse that lasts anywhere from an instant (the smallest partial eclipse) to around four hours (the longest total eclipse). Similarly, a solar eclipse could last anywhere from an instant to around 7 minutes.
Personally, I've always taken exception to measuring solar eclipses as the duration of shadow at a single point on the ground. If the observer is on the moon, he or she would see the moon's shadow cross the entire earth, and it would then be measured as up to four hours, just like a lunar eclipse.
