"My right toe works just great. Maybe should patent it."You have a right toe that can depress the release button, grab the Cessna flap handle, raise the handle against air loads, have your thigh miss the bottom right corner of the control yoke, and still operate the rudder pedals on your airplane while flying in Denali ???
Question: are you human or Orangutan in origin ?
For us normally proportioned humans, and for those of us who cannot use their toes to pick locks/untie knots/operate flap handles in flight, I humbly offer the EZ Flap device. It lets you sit upright, fly the airplane correctly, keep your face out of the instrument panel, and use the flaps with far better control, precision, comfort etc.
As for Andy Devine... everyone who watched the Twilight Zone knows that he's"the biggest gosh-darn liar there's ever been" and he didn't invent the rocket fuel after all. But if "Rocket Fuel Frisbee" knew that there needed to be an extension on the controls of a C-47, then there's darn sure justification for an extension on the Cessna/Piper flap handle
"Seems like you'd need to be kinda double-jointed to have ahold of that extension when the flaps are in the full down position- at least in the 170's & 180's I've sat in. And one more thing to be in the way the rest of the time. No offense to the inventor. Eric"Eric, no offense taken... if the inventor hadn't been quite as much of a genius as he was, you'd be right
HOWEVER, the aforementioned genius (that'd be me) did take that into account!
The Cessna version of EZ Flap is designed so that you can use EITHER the Cessna flap handle, the EZ Flap handle, or both, at any time and at any deflection. So although you could do anything your joints and muscles allow you to do, the NORMAL daily method is to use the EZ Flap handle between zero and 20 degrees, and the Cessna handle between 20 and 40... both putting the flaps out or pulling them back in.
You remain upright and comfy, pull the EZ Flap handle for the first notch, then the second notch, then pull the Cessna handle (which is now close and possible to reach) for the third and fourth notches. Same in reverse when retracting the flaps. This way you are always comfortable, always looking out at where you're going on takeoff or landing, always have your focus on flying the airplane, and never have to be double-jointed or have gorilla strength.
The Piper Super Cub and Cherokee flap handles do not require the long throw required that Cessna built, so the entire action can be done by holding the EZ Flap handle only. The PA-18, PA-22 and PA-28 EZ Flap units mount differently than the Cessna version.
