All those touch and goes are well and good, but I hope you're also doing a lot of stop and goes. There is good reason that the FAA says for recency in a tailwheel airplane, you must have completed three landings to a full stop in a tailwheel airplane in the past 90 days.
Ground loops almost never (actually, I've never heard of one) happen at touchdown speeds. They happen as the airplane slows and the controls become less effective and/or the pilot starts to relax. In training, most landings should be to a full stop.
The exception in my training routine is when doing one wheel landings. Turning landings are fine, but one wheel landings, and running the plane down a long runway on one wheel is the true test of whether you're flying the plane. Touch on the left wheel, keep it on the left only, then run it down the runway. First touch with left wheel on the centerline, then move that left wheel twenty feet to the left, then back to center, then twenty feet to the right, then back to center.....and play that game all the way down the runway. Lift off and do the same drill on the right wheel.
After you get that drill, touch on the left wheel first, then lift off, touch with the right wheel, run on it for a bit, then lift off, and touch with the left.....etc.
After that, turning landings are easy.
Nice looking airplane. But, you obviously need an EZ Flap handle.....
