My screen name is true, I am still learning. Some days quite a bit. I will have owned my 180 for 2 years on August 1. An IA that works for a friend looked over the plane before I bought it, I paid $1000 to another guy for my half of an annual on it before I saw it, then last July I had a friend do an annual on it. The guy that first looked it over before I bought it was not doing an annual, just an overall looking at it. He mentioned oil canning in the horizontal when the elevator was cycled, but did not do a thorough inspection to determine the cause, on the outside nothing was grossly evident. The guy that did the "annual", that I paid $1000 for, did nothing but look at it as well, no compression check, no wheel bearings, not even air in the low tire, but he did sign it off. After I bought it, I met a guy that was quite helpful with getting some small items taken care of. We rebuilt the fuel selector because it did not shut off, we put new O rings in the tank drains, and the gascolator, ended up replacing the tail wheel because the head was shot. We became friends and he did the "annual" on it this last July. I am new to this whole thing and at that point had respect for the man as a friend and an IA. But, I knew there were many things that were not done and questioned whether he had really inspected anything. I was helping him and he never asked me to remove many of the panels to inspect inside the fuselage or other areas. During the compression check, the #5 cylinder only got to 46 or 48, but he told me that if the motor were hot it would be over 50 and that was good enough to pass. I should have known better, but I still trusted him at that point. Over the next several months, I found out that the 5 hours he spent on the "annual" was a total joke.
This year I was bound and determined to have someone good truly look over the new to me airplane. So, I asked a friend that has two full time mechanics if his guys would do the annual. They agreed and I recently flew it 6 hours east to get it done. As I type this, it is sitting waiting for the overhauled cylinder to be put on, and the horizontal is at a shop getting structural repairs done to it. 10 minutes after I got to my buddies hangar, his guy and I went out and did full power runs and an brief assessment of it while running and taxiing. While doing this he asked what issues I have had, what in the plane worked and didn't work, all the while taking down notes. We got back to the hangar and immediately got to work. The compression check showed the #5 to be at 30 psi with a leaking exhaust valve, within 2 hours the cylinder was off and on its way to be overhauled. He also found 2 rivets with the heads popped off under the floor near the right gear box, old damage, rivet heads covered in oily dirt. Over the next couple of days he and another guy found improper hardware holding the left wing to the fuselage, and a throttle plate that only opened to about 80%. I removed the old engine monitor and started installation of a new 730, while at the same time removing 2 unused breakers, dozens of feet of unused wiring, the cigarette lighter that made lightening, a non-working clock, a non-working factory carb temp gauge, and other strange vestiges under the panel. After the inspection and the work on squawks started, they asked me about the "clunk" I had told them about when I have full nose up trim and make a turn to base or final. Within 3 minutes they had the problem located, a separated rib in the horizontal, the clunk was the horizontal flexing under load. Within an hour or so the horizontal was packed up and ready for my buddy to fly it to northern MN to get repaired. It was old damage, it was the oil canning that was present before I bought it.
My buddies guys checked every bolt, every hinge, every cable tension, the mixure cable, the throttle cable, the hot and cold air cables, they inspected every inch of the interior and exterior of the structure. I was shocked at the attention to seemingly unimportant things like the cabin air cable. All of the non-placarded stuff has new placards, all the hardware is correct, and soon the horizontal will be installed with new hardware.
The structural damage in the tail was not new, nor were the popped rivets in the belly, nor the heavily abraded brake hose coming off the right master cylinder, nor the dead cylinder, nor the inspection hole cut into the underside of the fuselage between the stinger mounts, yet two IA's had signed it off as airworthy. The "friend" that did last year's annual was with me many times when the tail "clunked", he told me it was nothing, that they all make some kind of noises.
When I fly it home next week, it will be the first time in two years that I have no concerns of the plane being sound, sad that it took 3 annuals to find the problems. It will be like a new airplane to me, with all six cylinders pumping WHILE getting full throttle.
