I agree with MTV, Headout, and Barnstormer.
As long as the wing is experiencing the same load in the same direction (such as 1800 lbs at 1g perpendicular to the wing, oriented straight downward in reference to the wing's span, at any constant speed where the wing is not stalled) the wing will not stall regardless of bank angle. Change any of those variables in the equation and you change the answer.
But whether it is or is not possible to bank 60 deg in the pattern is not relevant to how appropriate that maneuver might be. I'll say that it's not in most any situation except an emergency of some sort.
Cstol, I'm sure this isn't what you intended when you started this thread but there's goodness here. A bunch of seasoned folks (and some unseasoned ones like me) are reeling you back in from a level of complacency that you seem to have developed. We're doing it because we don't want to see you get hurt.
We've all been there in one way or another - my reeling in wasn't flying related but it made me analyze the way I approach most everything which included flying. It was unexpected and it was hard to swallow my ego when it happened, but I'm glad it did.
Just my two cents.
