feded wrote:How do you know the skybeacon is on? If the transponder light is flashing and no red light in the unit? correct? Or do you have to log into the app and check it?
hotrod180 wrote:[quote="soyAnarchisto'] ..... I can sometimes bump the switch for my Nav lights - and turn the tailbeacon off. ......
I think the app is the best way to verify its working......[/quote]
What I did when I installed my Tailbeacon, was to wire my aft nav light to it's own circuit breaker, connected to the avionics master switch.
Very little chance of forgetting to turn it on, or accidently bumping it off.
I just leave the nav light set to on via the app -- it's LED so should supposedly last forever.
Like I said before, I think the best way to verify it's working properly is to get a PAPR after a flight.
Do that a few times-- if it passes every time I wouldn't worry about it.
I get a PAPR check once every month or two just to verify it's still working right.
You can also check with other pilots to see if their ADSB-in is seeing you.[/quote]
