Last week I was in the Green River area bringing a plane back to Ogden and once again had to skirt around the restricted airspace. I got to talking with the other pilot I was flying a flight if two with about it and he asked what I knew of it. This prompted me to look on Foreflight to see if Denver was the controlling agency. When I opened up Foreflight, I read a note that I hadn't seen before. In Foreflight it says, "As published by NOTAM issued 48 hours in advance of area activation". Denver is the controlling agency. When I read that, I realized that this restricted area probably wasn't active all the time and didn't need to be skirted. The other pilot said that a friend of his worked for Redtail out of Moab and that they would routinely turn their transponders off and cut through it. I figured that the next time I went down there, I'd call Denver and ask about the status of the airspace.
Well, today, a friend of mine called from Moab to see what I knew of the airspace. I told him what I knew and he said that he would call the FSS and let me know what he found out. It wasn't long before I got another call from him. He told me that he called the FSS who contacted Denver Center. Denver Center said that it is activated by NOTAM. Then the guy told my friend that it was kind of a running joke/nuisance since they think the last time it was activated was 20+ years ago! They figure that they keep it charted because they don't want to give up the airspace for fear that they would never get it back.
So there you go. I feel kind of dumb for the time and gas I've burned going around it when I should have just asked Denver about it. With Caveman and other flying that goes on down there, hopefully this info will help someone out and save some time and fuel.
FYI, there is a strip right in the middle of the airspace. Time to go check it out!
