bat443 wrote:In the end, to each his own; you've got to decide what makes sense to yourself, your budget and your mission.
Bingo. To that I would add, most of us understand how vacuum systems work well enough to explain it during a checkride. The electronics coming out recently are quite likely a whole new space for many, many pilots. I feel I have a good grasp on what can break, why it will, and how various redundancies will kick in. I know my electrical system intimately. I can also see how someone new to this or with higher stakes (part 135, hard IFR, etc) will have serious reservations about disrupting an understood mechanism that has served aviation for many decades, even if it does break with alarming regularity.
If you're going to make a decision on risk tolerance (which is what this entire discussion is about), you need to fundamentally understand the systems you are debating.
I would break it down risk this, display being generic (G5, Dynon, etc):
Single display, no vacuum: Single point of failure potential. May not be IFR legal depending on what you use. Power supply can be redundant with battery but unit itself can fail.
Two or more displays, no vacuum: Gives redundancy for electrical-only approach. Each unit can have individual battery backup, and often can run independent of other display. Shared sensors can still be SPOF but AI-related functions are generally self contained. Lack of vacuum means you're still 100% electrical-dependent. Chance of multiple independent failures very small, but not 0%. Dual G5's are IFR legal as long as turn coordinator remains, dual D10's are not (can't replace DG yet but DG could be made electric as well). Primary displays should be fine.
Vacuum backup added in: Redundancy not tied to electrical system in any way. Vacuum systems will fail over time and require some level of maintenance. Minor added weight, plus many moving parts. Best shot at always having situational awareness, but higher maintenance.
Also consider that if you go a primary display route (G3X, Skyview/HDX, etc) and remove steam gauges doing it, (my opinion is that) you should always have redundant displays and power regardless of flight regime. Losing attitude awareness is one thing, losing all instrumentation is quite another. That also brings up a separate conversation on keeping backup steam gauges like airspeed and altimeter, which some opt to do.
