Value of Engine??
I'm cleaning out the hangar and I've got an old Continental core. Does anyone know the value of it? I'm looking to post it on barnstormers, but I don't know what to price it at. I do not have the log books for it. Thanks!
TxKiger on Mon Apr 13, 2015 7:07 pm, edited 1 time in total.
TxKiger offline
256
- Aircraft: 182
Let me know when you figure out what you want for it. I've got a friend looking for a core.
3386
25 years ago I paid $1500.00 for a C-85 core, I certainly wouldn't let it go for scrap metal price.
Dale Moul offline
523
Dale
Gravity Strikes Again.
If it is a -8 and the case and crank are good I'd say youve got yourself a pretty nice valuable there. Get some numbers off it and call the Dons Dream Machines guys.
gbflyer offline
2317
What I always hear is that a core is worth around $4K. Of course, if you're trying to sell no one wants to pay more than a grand, and if you're trying to buy no one'll take less than 6.
What's the engine time?
A C90 is in many ways the most desirable of the small 4 banger Continentals. Find a Cub or Champ guy wanting to re-engine would be my suggestion.
10534
No logbooks?
10514
Yea, unfortunately no log books. I might come across them cleaning out the hangar, but I'm not sure. My wife and I purchased a small airport last year and there were lots of parts left here with the hangar.
TxKiger on Mon Apr 13, 2015 7:08 pm, edited 1 time in total.
TxKiger offline
256
- Aircraft: 182
whee wrote:Let me know when you figure out what you want for it. I've got a friend looking for a core.
I will do that Whee , thanks for the heads up
TxKiger offline
256
- Aircraft: 182
Interesting, according to the data plate, that's a 14 F engine.
10514
mtv wrote:Interesting, according to the data plate, that's a 14 F engine.
I'm unfamiliar with a 14 F. Is that a particularly special engine?
TxKiger offline
256
- Aircraft: 182
Tue Jan 20, 2015 10:29 pm
The C90-14F question came up recently on the Cessna120/140 club forum. The -14F uses the same mount as a O200 where as the -12F uses the same mount as the C85. The discussion talked about how the engine mount for a -14F was shorter by a couple of inches than the engine mount for the -12F. In both cases the "F" means Flanged crankshaft for the prop mounting vrs to tapered crankshaft. Probably off a Cessna 140A.
bat443 offline
431
Core values can be all over the board!
A core that has been run regularly over the last 10 years and has reached normal TBO with no prop strike and crankshaft was at STD last overhaul and has all accessories and has complete logs and and and will be worth way more than a core that was found in the corner of a hangar! Who knows the core could have been out of a wreck with a bent crank, cracked case etc , or have been an A&P school engine that has all kinds of unserviceable parts that the students are supposed to find bad part in. (although it doesn't look like one of those) etc etc.
Just an estimate is to ask $1500 ish and expect to get $1000-$1200 or just sell it on ebay and let the bidding begin.
TangoFox offline
621
Keep the Greasy side down!
Thanks for the information everyone. You've helped out alot
TxKiger offline
256
- Aircraft: 182
