Backcountry Pilot • VG's on a Maule
VG's on a Maule
This subforum is meant to organize Maule-related topics.
9 posts • Page 1 of 1
VG's on a Maule
A buddy of mine has a Maule M7, he's thinking of putting a set of Micro VG's on it.
Can anyone here give a before-and-after pirep?
Different airfoils respond differently to mods, so Maule installations only please.
Thanks.
Re: VG's on a Maule
I put the micro VGs on my Maule MX7-180C after flying the plane for 3 years without them. My plane has Maule's "universal" wing, so the results should match for an M7. I don't choose to fly the plane any slower on approaches, but I do notice more roll authority at low speeds. I did not take any hits to my top speed, but Maules are not fast planes to begin with. I made the change to give myself more margin for errors at slow speed, short field landings and they seem to do that beautifully. I'd buy them again in a heartbeat. By the way, I bought my micro VG kit at the NW Aviation conference and tradeshow and got a significant discount. Your buddy may want to hold off until then to get his.
Re: VG's on a Maule
hotrod180 wrote:....Different airfoils respond differently to mods ....
I'm curious as to what airfoil the Maule wing uses?
I tried googling it, but found several different answers ranging from "same as a Cub", to "USB",
to "2412" (which is what the cessna wing uses).
Re: VG's on a Maule
Seems VGs are mostly the same story
Pro Improves low speed handling
Doesn’t improve much of anything else for outside of some GW STCs
Con Got to buy install and paint them and they occasionally fall off
Do you feel you need better low speed roll axis control?
Re: VG's on a Maule
NineThreeKilo wrote:Seems VGs are mostly the same story
I believe Maule employs the USA 35B mod airfoil from tip to root
Never painted any of the VG's I have installed...Cubs, Scout's, Cessna's, Beaver
Have had tail VG's bent over from rock impact and popped one loose due to a fuel can while overwing refueling but have never had them "occasionally fall off"
Yes, more low speed roll authority is a good thing, sign me up for more when available :wink:
TR
TR offline
Aircraft: PA-18A
C-180H
DHC-2
G-164 Ag Cat
Re: VG's on a Maule
TR
“Popped loose”, “fall off”, tomato tomato
Good tool for more roll authority when it’s needed
Re: VG's on a Maule
If you ever decide or need to use wing covers, or broom off snow, be prepared to cuss a lot.
AKJurnee offline
Re: VG's on a Maule
AKJurnee wrote:If you ever decide or need to use wing covers, or broom off snow, be prepared to cuss a lot.
Hmmm, never had an issue with covers and VG's in over 30 years and thousands of flight hours while employing wing covers (even on the high wing of the Beaver), perhaps due to my height and the dowel rod "tools" I made to lay/slip the covers on.
Kilo; Ahh, No, its not tomato/toMAto...losing one VG due to brute force impact over thousands of hours is much different than "occasionally fall off"
TR
TR offline
Aircraft: PA-18A
C-180H
DHC-2
G-164 Ag Cat
Re: VG's on a Maule
TR
Well if the VG aint there anymore it ain’t there anymore lol
I’ve been flying for half the time as you, big and small planes with VGs, IMO I like them in the air but I don’t like them in the hangar, if that makes sense
from a VG manufacturer
Cleaning
they include extras for when one ends up coming off (for whatever reason)
Apparently they REQUIRE you to keep the replacement kit and glue with the aircraft at all times
Been debating adding them to my skywagon
