ZPilot wrote:I am new in the videography / youtube world.
I made my first video.
It was shot in 1080 and 30fps with the Drift HD Ghost, and edited with KineMaster.
I'm not looking to make pro videos, however, as you can see it's studdering.
When played within the editing software on my PC, it runs smooth.
I read in Reddit that it can take a few hours within Youtube to smooth things out with uploads. Well, it has been 18 hours now.
Any tips?
I've uploaded hundreds of videos to Youtube as well as dozens to Vimeo and Facebook. Your video has something that's not a normal artifact. Normally on youtube what you might see is that the HD version isn't available for a few minutes to a couple hours. That presents itself as just a lower resolution version of your video. Not anything like what yours is showing.
You should be able to view the video on your PC before you upload it. I would expect that you would see the same stuttering issue there. Don't view it in the editing software, use something else (I'm not sure what to recommend specifically as I haven't used Windows in 20 years or so).
Try different software. Again, I don't know what the new hotness is on Windows, but in terms of isolating the problem you can try *anything*. Don't spend a ton of time, just put together a video with 10 clips strung together and upload it to youtube. If it works, then you have a very strong indication that the problem is KineMaster.
That should get you started.
