Backcountry Pilot • Washington grass strips
14 postsPage 1 of 1
Starting to explore some grass strips near my base airport.
S88 S86 and 1WA6
Cheaper fuel, no landing fees, beautiful scenery.
Like it so far :)
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Re: Washington grass strips
Nice video! Is this the same plane you had in Costa Rica?
How about the HUD (I am assuming that is is a HUD)? Is that for the AOA indicator?
Crzyivan13 offline
Aircraft: 1957 Cessna 182A
I think Skykomish is closed right now according to WA Dept of Aeronautics. Maybe not, I dunno. I was planning on heading out to Tieton this week but called them and they said June 1 is the planned seasonal opening, which seems to be the case for many state-managed strips.
http://www.wsdot.wa.gov/aviation/Airports/Amenities.htm
Yes same plane, flew it from Costa Rica.
The HUD is for AoA works really nice.
Although the conditions were good, later on I found out S88 is closed , I didnt know it though.
motoadve offline
CJ 6 Nanchang
Cessna 170B
Harvey (S43) has a parallel grass strip, not super back country but a nice little airport with a good diner and short walk from their downtown.
Copalis is also fun, but it's a beach
Lost River W12 is east but a fun little strip.
I probably flew past you at some point, if you were flying Saturday. I flew across Stampede on Saturday for a late lunch at Harvey Field (S43). At some lunch at the resteraunt and watched the skydivers for a bit, then headed home. You might give that a try sometime, nice field and town is closeby as well.
Where are you based out of now?
BlindPilot offline
Aircraft: 1966 Cessna 182J
Great video!!
Crzyivan13 wrote:How about the HUD (I am assuming that is is a HUD)? Is that for the AOA indicator?
motoadve wrote:The HUD is for AoA works really nice.
I really like that set-up. Which one is that?
Alpha Systems.
motoadve offline
CJ 6 Nanchang
Cessna 170B
CamTom12 wrote:Great video!!
I like it too.
http://www.alphasystemsaoa.com/valkyrie.html
Crzyivan13 offline
Hi. Glad you finally made it ! I look forward to meeting you someday in the PNW BC
DAN
Mr Steel offline
Aircraft: Maule. M -5 235
Cessna 150
motoadve,
Very nice approaches, all!
There was just a bit of Dutch roll, dynamic proactive little coordinated turns, to stay aligned on approach two. Not at all a problem there, but can lead to the use of the shallow coordinated turn, below tree level, to align on the third approach.
A rudder only turn, while keeping the wing level with aileron, is the safest turn below the trees to line up on a crooked approach path. This prevents putting a wing down into wires or terrain, especially on a very crooked approach requiring either aggressive banking or aggressive rudder turning.
Maintaining alignment on final with rudder only, regardless of wind, and keeping the wing level or banked into the crosswind with aileron is a habit that will prevent unexpected wires or uneven terrain or obstacles becoming a problem in the future. In a nose down angle of attack, uncoordination (rudder turn, skid, or slip) is less of a problem than putting a wing down near the ground.
Again, very nice approaches, all!
contact
There's a number of grass strips around the Puget Sound area, both charted and uncharted.
My personal policy is not to land on a private airstrip unless I've been invited.
And I mean invited by the owner- IMHO "oh, everybody does it" or "just tell them Charlie said it's OK" doesn't cut it. Therefore I'm not gonna identify some of the ones I know about.
A good example of a low-profile private strip is the one near Duvall I think you went into with Jon when you were up here last year. Uncharted, and although I've been flying Puget Sound for 20 years I never even knew it was there until Jon told me where it was. As time goes on, and you spend more time flying the area and meet more locals, you'll get in on some of them.
There's awesome flying up here.
I'm curious how you got into 1WA6, I fly by there all the time and was told it's definitely private and few get permission to land. That's hear-say though.
Tomahawk49 offline
Aircraft: C172D 180hp / C177B
1WA6 its dfinitely very private, I base my plane out of there.
motoadve offline
CJ 6 Nanchang
Cessna 170B
14 postsPage 1 of 1
