A1Skinner wrote:Great question Zzz. Most snowmobiles today are efi and work great with pull starters, I'd think hand propping should work similarily well...
whee wrote:A1Skinner wrote:Great question Zzz. Most snowmobiles today are efi and work great with pull starters, I'd think hand propping should work similarily well...
I don't know if this really applies. It took sled manufactures quite a while to get it right. Maybe it has to do with the slowness of the revolution when hand propping that makes it difficult.
Battson wrote:whee wrote:I don't know if this really applies. It took sled manufactures quite a while to get it right. Maybe it has to do with the slowness of the revolution when hand propping that makes it difficult.
I guess if you're trying to hand prop the engine, it's because the battery is flat. I think EFI needs battery power to work?
Zzz wrote:Hmmm. So the question is: does modern electronics and efficiency trump good old backcountry self-sufficiency? If you drain the battery while camping out in the middle of nowhere, do you setup the solar charger and read a few books? Maybe write one?
Zzz wrote:If you drain the battery while camping out in the middle of nowhere, do you setup the solar charger and read a few books? Maybe write one?
highroad wrote:I agree on the hot start not being an issue once you figure out your technique for the specific installation. The one change I would make to my Maule is to add FI.........
Battson wrote:Are you thinking vibration profile, or are you thinking balanced fuel flow and therefore ability to run smoothly at different power settings?
