Backcountry Pilot • What batteries are you guys running?
75 postsPage 3 of 41, 2, 3, 4
Re: What batteries are you guys running?
Some 12 years or so ago, I replaced the sorry excuse for an "airplane battery" called Gill with an SBS J16 Odyssey on my 170. Pulled existing battery out of stock box, inserted smaller battery, shimmed it with non flammable foam, connected it and went flying. Later, my mechanic at the time got nervous and got it field approved. If it made him more comfortable, it was okay with me.
I wouldn't bother removing the battery box in a 170 to install one of these unless the battery box was badly corroded. Mine wasn't. If it had been, I'd just buy one of Atlee's brackets, remove the corroded battery box and install the bracket in the same location.
Don't forget the W/B change.
My original Odyssey was replaced after a number of years...8 or ??? just because I knew it was getting old. Worked fine. It still starts my lawn tractor, though.... :lol:
This is my battery (picture below) and its only 2 years old. Some you may have read above my need for a jump in my ski flying thread. Anyhow trying to address the problem. Getting a new battery today. Going with this one again:
http://shop.odysseybattery.com/p/pc625-p?pp=12&pp=12
So hopefully I wont be doing this again...or hand starting it like you see in the other photos I posted... #-o
Also putting in a new Starter Solenoid. Skytec Starter is brand new...
AKT
The experiemental "Aerovoltz" Lithium battery I am using weighs about 950grams (~2lbs) and claims to have about 510CCA, or enough to cold crank 6 cylinders for several minutes (I think). Hard to believe when it's so small. Cost all of $170 bucks.
There has been some discussion recently on the Aeroelectric list regarding lithium batteries in aircraft. They are really neat technology, but are not ready for prime time in airplanes, yet. Of course being experimental, they can be used, however being forewarned is forearmed... It might pay to have a good fire extinguisher, too. They have a very small temperature and voltage operating range.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Robert L. Nuckolls, III
Sent: Tuesday, January 08, 2013 10:01 AM
To: [email protected]
Subject: AeroElectric-List: Lithium batteries redux
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III"
--> <[email protected]>
This morning's news included a bit concerning a battery fire in a B787 on the ramp at Boston airport.
http://tinyurl.com/bx3ww23
According to Skip Koss (and unlike the
Cessna ramp fire in the Citation) this fire appears to have been controlled by individuals both trained and equipped for dealing with a lithium fire.
A123 (manufacturer of the cells in the Cessna
battery) is shut down in bankruptcy although I understand they've been purchased by a Chinese interest.
Folks. I think it's pretty clear that the large energy storage lithium products are not ready for prime time on airplanes. There's a lot of ground based history being made and new product development being conducted which may ultimately evolve into products with aviation-grade failure modes and risks . . .
let us wait and see.
Sometimes, the best way to drive a nail is with a hammer and the best way to carry a reserve of electrons is with lead-acid.
http://tinyurl.com/3atma44
Bob . . .
blackrock offline
Aircraft: Bearhawk
He seems to draw a conclusion without any meaningful evidence to support it? I fear he's on the bandwagon enjoying the ride.....
Any kind of battery can fail catastrophically if mistreated - and specifically, you don't want to simply replace a Pb battery with a modern Li one and expect to treat them the same. They have a different operating regime and a more concentrated power source is clearly a bigger risk if you misuse it. I understand they cannot be recharged from flat (they are stuffed by that point), and don't like being overcharged or fast charged. Not great operational properties, but if they were just smaller and lighter without any drawbacks then we'd all be using them.
http://www.ainonline.com/aviation-news/aviation-international-news/2012-10-04/lithium-fires-generate-myths-and-misinformation
I did the Odyssey sbs-j16 switch in my 170a about a year ago with the F. Attlee Dodge box. The sbs-j16 is approved in the 170 only with the box or a field approval. Much discussion as to the need for approval or only a log book entry, but I decided to go the easy route with the stc. Very happy with both the box and battery. With the skytech starter combo it barely turns over before it fires!
Brent
cowpilot offline
'49 170A. (his)
'56 172. (hers)
Battson wrote:He seems to draw a conclusion without any meaningful evidence to support it? I fear he's on the bandwagon enjoying the ride Mike.....
Hmm... Bob Nuckolls is pretty much the guru of aircraft electrical systems and is very well regarded. Most Experimental builders follow his work very closely with excellent results. Keep in mind the email I posted is only one email exchange of many, especially over time so there is a lot more info out there and the jest of this discussion has been on-going for some time. Bob (now retired from Hawker/Beach) has nothing to gain from this. I've never heard of the reporter who wrote the article, however I'd wager his employer has a lot to gain by keeping their big dollar advertisers happy.
Also, as Bob pointed out in another email, just think how many millions of dollars have gone into lithium battery research and how many more millions have into certifying these in airliners and other commercial aircraft by Boeing, Cessna, and others, and apparently they still don't have it right yet. That is certainly worth considering...
I'd love to use a lithium main battery. It just doesn't appear, according to at least one highly regarded and impartial expert, that the larger rechargeable lithium batteries are ready for aircraft use yet. The AA lithiums work great in the Zulu's, however. :D
blackrock offline
Aircraft: Bearhawk
Yeah I guess it depends what we're talking about when we say "larger batteries". Like you say, forewarned is forearmed. A 2lb battery for a light single is somewhere between a cellphone battery and a 100lb battery for an airliner in terms of risk. Nevertheless they seem to be widely available and in use today with experiementals.
Are you able to re-post any of the technical content behind his conclusion?
Battson wrote:Are you able to re-post any of the technical content behind his conclusion?
You'll find it scattered through the Aeroelectric forum in the first link below, which I highly recommend to anyone building or who has an interest in aircraft electrical systems. There is a lot of great information passing through the that forum. I also highly recommend getting a copy of the book from the Aeroelectric connection - see last link below. The wiring diagrams alone are very worth having. The rest of it is like a text book; I learned a lot from it, followed his guidance closely, and have had nearly 600 trouble free hours from a really well designed electrical system. =D>
http://forums.matronics.com/viewforum.php?f=3
http://www.aeroelectric.com/Downloads.html
https://matronics.com/aeroelectric/Catalog/AECCatalog.html Scroll down about 1 page to order the book.
blackrock offline
Aircraft: Bearhawk
Some more email discussion from the Aeroelectric list on lithium batteries follows. Just go to the forum and do a search for "lithium". Not all posters agree on the risk and all have their justifications. It just depends on your risk tolerance I guess. I learned a long time ago when buying car tires or batteries to only go with proven, high quality ones. I spend too much time in remote places to dick around with dead batteries or flat tires. I've just applied that experience to airplanes - same thing.
nuckolls.bob(at)aeroelect
Guest
PostPosted: Tue May 29, 2012 9:28 am Post subject: Lithium aircraft batteries Reply with quote
At 11:15 AM 5/29/2012, you wrote:
Quote:
This technology is outside my field, so I am appealing to others for insight:
‘aircraft battery’ from: wicks aircraft
Underlying technology: a123 systems
There are a lot of hand-waving claims on these batteries, but not a lot of hard technical data. I’m sure that they can be adapted for flight, but some thoughtful ground testing would be useful. Thoughts?
Vern
Li-Ion batteries for have been the Holy Grail
for the TC aviation battery guys for quite some time.
HBC was up to their eyeballs in studies for weight
reduction without sacrificing performance before I
left. I spent a significant amount of time studying
battery issues for HBC in both the legacy (lead-acid)
and shining-star-on-the-horizon worlds.
To Cessna's credit, they spent a barrel of money
and a lot of person-hours getting a Li-Ion product
qualified for their aircraft. In fact, I think it was
a brand new Citation being prepared for a big show
that was fitted with a Li-Ion that caught fire on
the ramp. This experience highlighted a few of
the snakes not yet stuffed into the sack . . .
Nobody had the slightest notion how to fight a lithium
fire . . . nor were they provided the equipment
to do it.
Rumor has it that the battery was being charged on
ground power and some hitch in the systems management
software intended to prevent this accident wasn't
minding the store. This is a RUMOR . . . I'm not yet
privy to inside information of reliable source.
Nonetheless, the incident sparked a rapid recall of
all Li-Ion batteries still in the States. Since
two airplanes were out of the country, Cessna's
prophylactic against another occurrence called for an
A/D to remove the Li-Ion battery in favor of
SVLA or NiCad.
I was asked to evaluate a Li-Ion product for suitability
as a cranking battery on a TC light plane. The inquiry
arrived just weeks before the Cessna ramp incident.
Shucks, if Cessna could do it, I was inclined to
favor use of this particular technology (Li-Fe)
in the putt-putt.
Yes, thousands of these batteries are in service
everywhere and the owners of these batteries swear
by their virtues. Nothing like consumer enthusiasm
to drive up numbers of folks willing to wade in.
It's a simple caveat emptor situation. If the weight
of demonstrated successes combined with the weight
savings is sufficiently powerful to encourage your
own experiment, the risks are not scarry. . . but
probably 1000x greater than for hazards demonstrated
by SVLA devices (read this to mean that SVLA batteries
are exceedingly low hazard).
The other question to be asked and answered, "Okay,
I've saved x.x pounds'. Now how do I use them?"
I'm sure there are times when I left the ground
a few pounds over-gross . . . not sure I'd spend
extra dollars to stay under-gross no matter how safe
the battery might be.
A single weight-savings effort almost never offers
a good return on investment. A TOTAL weight savings
effort produces an airplane like Voyager that was
sucked dry of no-value-added weight. It took
5 pounds of fuel to carry 1 pound of airplane
around the world. 1 pound of empty weight was 6
pounds added weight at takeoff and perhaps 100
miles less range. This thought process produced
an airplane that Dick Rutan feared. He wrote of
nightmares about this airplane killing him.
Someplace between goals and risk assumption
for around-the-world-flight . . . and taking off
for a nice weekend with the wife in Santa Fe, there
is a very comfortable middle ground that probably
is not improved by swapping out the plastic box
of lead for a box of lithium.
Bob . . .
[b]
blackrock offline
Aircraft: Bearhawk
You guys got to get your chemistry straight of what you mean by "Lithium". There's different types out there, some OK some not. For example, every airliner now has about 100 iPads on board any given flight, including a few in the cockpit, each with a pretty substantial lithium battery. Nobody is worried about them, especially the FAA.
Now for starting an airplane, or powerpacks for GPU starts, or EMS interior battery power until the engines spool up, there's a whole movement to LiFePO4, such as the Shorai or Aerovolz. Good MIT technology that washed up on the eager investment shores of China. For you Alaska guys, just a caution that they like to be a little warm before they really crank. Most homebuilders are switching to them, and as posted on this thread a battery is a battery, nothing stopping you putting it in your airplane except a 337 (maybe). These are not the same as LiPO, lithium polymer that you find in the typical RC application. The LiFePO4 batteries are flying off the shelves into motorcycles, so we're not breaking any new ground here. I haven't heard of a single motorcyle immolating itself due to a LiFePO4 battery.
Some stuff I fly has battery heat sensors, and we've had to put down the odd time to toss out a battery that was going into meltdown and flashing a "Battery Hot" light on the panel, and that was with the old "safe" tech. You decide for yourself when a 3lb new-tech battery is going to replace your 30 lb lead acid, but please hold off on the fear-mongering fables as the only reason for not moving ahead.
Karmutzen offline
FWIW, I'm still 100% pleased with my Concorde AGM, installed 2 years ago, Feb 2011.
Karmutzen wrote: ...but please hold off on the fear-mongering fables as the only reason for not moving ahead.
Karmutzen,
I do apologize if any of this offends you, however an open discussion and sharing of information should not be stifled especially when it is related to safety concerns. I think this discussion relates more to individual risk tolerance as far as possibly having to deal with an an in flight electrical outage, or the much less likely occurance of a battery fire. We are all big boys and ladies on here and when presented with information, I think we are all capable of assessing the risks for our selfs and I beleive you concur.
Your points are as valid as anyone else's so thank you for sharing and I hope you will continue to do so without openly critizing and judging others who are simply exchanging information.
To that end, this is a link to Avweb with some additional discussion about Li-ion batteries. Bye the way, while rare, Li-ion batteries in laptops, cell phones, and other devices continue to catch fire. Simply google lithium ion fires.
http://www.avweb.com/blogs/insider/AVwebInsider_DreamlinerFire_207979-1.html
blackrock offline
Aircraft: Bearhawk
I'm looking at putting a gill 35s in my 182.
On the li-po discussion. Remember this one as well..
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/0/1a1f5bfbc840987f8625793b00494edd/$FILE/2011-21-51.pdf
soggyc offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... KhvYFzCT8z
Apologies, no offence intended. It was a worthless post anyway as it tried to differentiate between different lithium chemistries, and doesn't appear to have gotten the message across. Someone else can take a shot at it.
Karmutzen offline
I think most of us are learning as we go here and I've also hijacked the thread. Zane does it make sense to split the discussion of Litium Batteries to a separate thread?
I was incorrect using the generic term "lithium" when referring to" lithium-ion" batteries of which there are several types, hence the ion designations Fe, P, Co, Mn, etc. there are also lithium polymer batteries and regular lithium batteries such as the AA style we can buy at grocery stores.
I think that is what you are refering to when you mention the different chemistries. I know very little about the differences however I'm getting the impression that while some are believed to be more stable, there just isn't enough history with the Li-ion chemistries to know with certainty how they will behave over time and in different applications.
http://en.wikipedia.org/wiki/Lithium_battery
http://en.wikipedia.org/wiki/Lithium-ion_battery
http://en.wikipedia.org/wiki/Lithium-ion_polymer_battery
blackrock offline
Aircraft: Bearhawk
mtv wrote:........I wouldn't bother removing the battery box in a 170 to install one of these unless the battery box was badly corroded. Mine wasn't. If it had been, I'd just buy one of Atlee's brackets, remove the corroded battery box and install the bracket in the same location.......
I don't know what the Atlee Dodge bracket looks like, but Odyssey makes a very nice little bracket which is what I'd use if mounting an Odyssey battery on the firewall. Spruce p/n 11-01853, $39......which is about 10% of the online price for the Atlee Dodge bracket. Whew!
Thanks with your time guys helping with this.
Hotrod,
I noticed that same Odyssey box on the Odyssey website:
http://www.odysseybatteries.com/accesso ... 80_545.htm
Even less than Spruce. I also noticed that it's made out of aluminum, where as the shops with the STC's are making them out of stainless. I don't know if that's for any important reason, considering the firewall is stainless. I suspect that the stock 170 batt. box is aluminum anyway.
I also noticed that Burl's STC has a heat shield included, where as Atlee doesn't.
As far as MTV's recomendation, my stock batt. box is in good condition, but working with metal is one of my favorite things to do on the plane (however, for every sweet piece I manufacture in the hangar, there are usually a few prototypes in the scrap pile before from the learning curve is realized). If I am successful with a 337, I would enjoy making a real nice box for a clean looking conversion/installation.
http://www.skywagons.org/uploads/9581-N323EB026.jpg
The above batt. box has the standoff to clear the seaplane engine mount, and that's kinda how Atlee Dodge's box looks. I would like mine to be similar, but flat up against the firewall and of course have some kind of hold down strap which I don't see in this pic.
Any way, thanks again. I'm still plugging along.
PS. I flew the plane yesterday after hand propping it from dead batt. After getting gas I got in and; click click click.....
One year old G-25. Up until yesterday it would start after the initial flight and everything was warmed up. Now she's dead dead! Working through Gill via Chiefs today to see if the warranty will be honored, which will buy me more time to work on the 337 route.
More to come.
Good day.
Tom
TomW offline
Tom Weiss perished in a mid-air collision October 12, 2014. He was an enthusiastic and beloved contributor here for close to 10 years, and he will be missed greatly.
blackrock wrote:To that end, this is a link to Avweb with some additional discussion about Li-ion batteries. Bye the way, while rare, Li-ion batteries in laptops, cell phones, and other devices continue to catch fire. Simply google lithium ion fires.
The interesting thing is, Ni-Cad batteries are also able to catch fire and they do crop up about as often if you go through the records - but you don't get all the hype there. I guess because it's not happening in peoples front pockets (important stuff close to there!!) #-o :twisted:
I'm with blackrock in regard to Bob Knucholls and the Aerolectric email forum, book and website. Bob is an impartial and very highly regarded aviation electrical system expert. I used one of his designs for my electrical system when building my plane...never an issue and I learned a tremendous amount through sources he provides. If he says it is so, I would believe and follow. That simple. Good discussion on these issues. Thanks.
Bushcaddy offline
