Whatever happened to the “Spade Style" control stick that was ever popular in many WWII aircraft and after the war as well.
As was pointed out in the discussion on another website forum (link below) there are some definite ergonomic advantages. As one fellow noted:
I know Zenith has a sort remotely similar Y stick in their side by side airplanes like the 701/750/801. The Spade Style stick might appeal to side by side as well as a tandem configuration..
The ring grip at the top of the stick has some ergonomic advantages - You can grip it palm up, palm down, or in between, and with either hand or both if need be. The Brits used it in combat aircraft in WWI through WWII and into the jet age...
Great Discussion:
http://www.homebuiltairplanes.com/forums/hangar-flying/2388-control-sticks-columns.html
Image – Spade Stick British Spitfire
Image – Spade Stick Russian Aircraft
Image – Spade Stick British Seafury
So, imagine yourself flying along in your Experimental. It seems a Spade Stick configuration might be quite an ergonomic option if there is enough room in the cockpit. I wonder why they are basically extinct ? Too expensive to manufacture? Out of fashion? More of a "European thing" like Russian props that swing in the other direction? Anyone...??? I'm just curious.
