robw56 wrote:I'm going to be putting in a new one piece windshield in my 170 which will eliminate the center strap. I'm trying to decide which kit to go with, LP Aero or Great Lakes Aero. The LP Aero STC uses a new upper retainer strap to hold the windshield in place. The Great Lakes Aero STC uses 4 screws that go through the top of the windshield and into the airframe. Those of you that have been there and done that which windshield do you recommend and why?
I went to the LP because too many times I see plexi crack where it has a screw passing through a hole. I realize this is an installation or drilling flaw, but never the less, boo-boos happen, and this type of flaw will go unseen until the cracks start. Replacing a windscreen a year after you install it will suck. Also, don't get so aggressive trimming the bottom. I had one poor installation (by a big reputable shop), that popped the bottom 'corner' up out of the strip while boon docking in Alaska. This turns in to quite a PITA to address in the field. A vee brace or flying wires will lessen the airframe flex and alleviate this, but so will a proper install. On the vee brace note, if you haven't installed one yet, you may consider going with the wires. I believe Gary has set the groundwork in motion for being able to do that on his new 170.
And lastly, you appear to be building a light weight bush beater. Take a good look at the weight differences before you ditch the center strap. I went strapless, but had a hard time making that choice, given the weight difference over the stock windscreen. I'm not interested in the 'latest greatest' or what's in vogue, and the only reason I wanted the strap gone was because I added flying wires and wanted to minimize the stuff in my field of view. YMMV
Take care, Rob
