Will this C 310 fork fit in my 182?
Mine is a 1973 P model 182.
Will this Cessna 310 frok fit?
motoadve offline
1423
- Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
part number is 0842000-30
motoadve offline
1423
CJ 6 Nanchang
Cessna 170B
Tue Jul 08, 2014 12:45 pm
Looks like the exact one I put on my C175B. I would think it would work, waiting for others to respond.
Dave
RangeFlyer offline
75
Dave R.
It will fit!
If you have the piston with 2 holes (older 182) you will need to cut off the bottom one. Take to a machine shop and get them to do it with a lathe then put a slight chamfer on the bottom so the block will go on easier.
Also will need to get a field approval.
TangoFox offline
621
Keep the Greasy side down!
Tue Jul 08, 2014 11:44 pm
Yes that will work. I just removed one from my 182. I also could give you a copy of a field approval 337 if you want. Not much data besides the faa stamp but that might be enough to get it through your guy.
PAMR MX offline
469
You might get away with just a logbook entry. The HD fork may be listed in the 182 parts manual, and it is generally the 310 nose fork. It was in the parts manual for my 74-182 and only required a logbook entry.
rfinkle offline
334
- FindMeSpot URL: http://share.findmespot.com/shared/face ... gujelTKUbh
