Backcountry Pilot • Windshield Scratch Repair
7 postsPage 1 of 1
As the days are getting shorter up here in the Maine, I find my self dealing with more low light conditions, and staring into sun through the windshield. Like many people with older planes I have a good deal of scratches in the windshield, and when looking into the sun, it makes the visibility very low and some times unsafe on short final. Wondering if any one has tried to repair the scratches by polishing or any other method, or is the only solution to replace the windshield with a new one.
tbabbott offline
Aircraft: Cessna 180H
Re: Windshield Scratch Repair
Polished a few windshields that were scratched, and one that had turned yellow and I sanded the yellow off with 600 grit sandpaper wrapped around a sponge. I use a power buffer and Novus brand scratch remover/polish it comes in 3-steps, works fine.
https://www.aircraftspruce.com/search/s ... c%20polish
Dale Moul offline
Dale
Gravity Strikes Again.
So on the subject of windshield care & feeding is it better to cover it from the elements and run the risk of abrasion from grit etc under the covering or use an internal heat shield and leave the windshield uncovered, inquiring minds may want to know !!!
Aryana offline
Aircraft: 1955 Cessna 170
niente qui
dogpilot offline
Took ball and went home
I sanded my windshield down with 800 then 1200 grit. then used this kit using a drill at very slow speed
https://www.aircraftspruce.com/catalog/ ... hoff_1.php
only spent a few hours and came out with a 90% to new
Tangogawd offline
Aircraft: '62 C-180E
'69 7GCBC
Crest toothpaste and a buffer with a fine pad. It'll look new when you're done. Polish it with a good uv protectant when you're done.
This stuff works well:
https://www.aircraftspruce.com/catalog/cspages/cavu09-04611.php?gclid=Cj0KCQjwjvXeBRDDARIsAC38TP5wrDmCU53LfsQ1Tj799qajVKgtcYA2bTvUMVfhzzuomDpkmEaUSs4aAmlmEALw_wcB
jaudette offline
Aircraft: Husky A-1B
Vans RV-7a
7 postsPage 1 of 1
