TomD wrote:I got to wondering if you don't add any heat to the engine compartment while the plane is sitting outside, does it really matter how thick or reflective the cowl covering really is?
After a certain amount of time everything will reach equilibrium at the ambient temperature. I vaguely remember a couple of long forgotten formulas from from physics about heat flowing to lowest temperature etc.
Hunks of iron don't recognize wind chill, only actual temperature; but the pilot sitting next to an engine preheater is a totally different story.
TD
I also like to throw a good cover on ASAP even if I don't intend to restart soon. I figure it helps protect the engine from unnecessarily rapid (aka "shock") cooling on really cold days.
TomD wrote:I also like to throw a good cover on ASAP even if I don't intend to restart soon. I figure it helps protect the engine from unnecessarily rapid (aka "shock") cooling on really cold days.
I agree if you are going to get right back in after a couple of hours a blanket is a bonus.
I had not thought about "shock cooling" . This Georgia boy don't do extreme cold!!
TD
denalipilot wrote:I'll throw in my $.02 here.
On the engine cover, I am due for a replacement of my ratty 2nd-hand one. I have some fabric samples from Aviation Covers that I requested last year. The owner, Joang Shaeffer, has been very responsive and helpful so far, answering questions, offering to customize, etc... Only reason I am holding off is that I would like to get some testimonials about their "Thin Engine Cover" material. It is about 1/4" thick, with a layer of mylar or metal foil sandwiched inside. I have a hard time believing that this insulates as well as the 2" thick blankets I see around MRI and FAI. Also skeptical that the foil won't get brittle and crack in the extreme cold. If anyone has experience with this material, pireps appreciated.
-DP
-DP
I intend to get my act together and call in an order in the near future.
