Wiring Harness
A question for those who have done a panel upgrade, did you pre-build your wiring harness on the work bench or insitu ?
2324
Just the little bit of avionics work I’ve done on my 182 and the resultant rat’s nest behind my panel, I’d recommend do as much as you can on the bench, then install!
AK737Pilot offline
50
- Aircraft: Cessna 182L
