Backcountry Pilot • WTB: analog split M.P./Fuel Flow for IO-550
11 posts • Page 1 of 1
Anyone have a take off laying around?
Thanks
gahi offline
Aircraft: PA18
Re: WTB: analog split M.P./Fuel Flow for IO-550
Took one out of a 185 at Park Rapids Avionics...As I remember it wasn't real accurate, you might check and see if they still have it, could be rebuilt.
wfd offline
thanks, looked on their site, and found this one. The fuel flow range is way off on as far as what GPH goes to PSI, but might be able to remark that. Should be 26.4 @ 20PSI
gahi offline
Aircraft: PA18
Like this?
PNW Flyer offline
Aircraft: C182P
yes, like that.
gahi offline
Aircraft: PA18
Don't you need more than 24 gph for a 550???
wfd offline
wfd offline
yes, the required max spec is 20psi/26.4 gph.
gahi offline
Aircraft: PA18
Have one from a IO520 that was working fine when removed.
peterdillon offline
Aircraft: Floats
I have one that looks like those, but has electronic sending units. It was installed with a 550. [email protected] if you’d like to take a look.
Tony
AEROPOD offline
I have exactly what you need. Removed from a wrecked 182 that had an AirPlains IO-550. It was manufactured in July of 2014, it is a United Instruments 6331 and is in perfect condition. The engine hours were 440 when the plane had a ‘rough’ landing.
I can’t post a picture, but if you shoot me a text at two.five.three. 584. One seven 9 4 I can send you pictures.
I also have an EI GCR-30P with all of the wiring harness and probes for the IO-550, if you need to spend some additional money before year-end :-)
SpamCanFlier offline
