Backcountry Pilot • WTB: early 180/182 filler neck
9 posts • Page 1 of 1
My ‘53 180 has a leaking filler neck, when all the way full fuel seeps from the base of the neck. I’m assuming that all the wedge tank and even the square tank models used the same filler neck. It’s a round plate with the filler neck offset, sandwiches between the bladder and the tank lid part.
I could probably seal this one up, but I’d rather not put sealer on something that could end up in the tank. And this one is bent, probably from a filler hose hanging on it.
StillLearning offline
Re: WTB: early 180/182 filler neck
Two thoughts....can this be brazed by a good torch pro..... you’ll have to remove it either to replace or repair....might call Lucky at Air Salvage in Dallas......he has encyclopedic knowledge of older Cessna’s and repair procedures.....good luck
Airdave100 offline
Aircraft: 1956 Cessna 182....N5632B
Maybe the bladder manufacturers /overhaulers would have this part?
I think I might have what you want---will look in a few hrs and report back.
I found one that I took off 33 yrs ago stored in not the best environment. I think the sealing part of the neck has not been bent and it was sealing fine when replaced with the "original" Monarch caps.If you want it you can have it and donate what you think it is worth to Zane.
[img]
[/img]
That's the part.
Thank you, I will take it. PM inbound.
I think I have a couple if that one doesn't work out.
AEROPOD offline
StillLearning came down from Sioux Falls this morning. Always neat to meet another 180 pilot.
Great to meet a fellow Wagon driver. Nice day to fly in March, before another storm rolls in, and I have a new to me filler neck!
