Mapleflt wrote:I'll point you at TurtlePac once more, there are pictorial examples of set-ups on their website. I'd copy the site address and post it but I'm not sure if thats complient with the BCP site rules.
One though might be a TrutlePac inside a conventional belly pod. It could then be removed leaving the pod for other uses when not required for extended range operations.
JamieG wrote:Mapleflt wrote:I'll point you at TurtlePac once more, there are pictorial examples of set-ups on their website. I'd copy the site address and post it but I'm not sure if thats complient with the BCP site rules.
I have tried to get a Turtle Pac to fit in the Cessna Pod. Too expensive to get one made specially to fit. Only the 37 Gal ones will fit. I have decided to put the bladder inside the cabin and use the pod for storage. Also if something goes wrong I can engage the autopilot and try and fix it if you have it in the cabin. Roll it up and stuff it in the pod once you have arrived, (NZ to Aus)
Regarding the Sorenson. There were two sizes and 180's did have them in the early days.
