Zzz wrote:…….Trim on the Pacer is a stabilator controlled by an overhead crank.......
Zzz wrote:Weight:
170A will be heavier with empty weights around 1,300 lbs
Pacer weights can be as low as 1,050 lbs
Zzz wrote:Engine:
170A uses a Continental C-145 6-cylinder.
Pacer 150 uses a Lycoming O-320 4-cylinder. Lower weight nod goes to the Lycoming IIRC.
Zzz wrote:Construction:
The 170A is all aluminum
The Pacer is steel tube fuselage covered in fabric with some aluminum panels at the boot cowl and belly.
The 170A is an all aluminum wing with aluminum skins and a single strut.
The Pacer has a wing with aluminum spars, ribs, leading edge, but is covered in fabric. Internal rods are used to brace the wing from racking. It has two lift struts per side.
For some guys, this is everything. I personally prefer a steel fuselage and fabric.
The Pacer only has a right side door, like many Pipers. There is an STC to add a left side seaplane door but it's somewhat invasive.
Zzz wrote:
Performance:
Performance is an amalgam of many things. Where do you value performance the most? Slow speeds? Cruise speed? Load carrying? Handling?
Props being equally pitched:
The 170 will likely fly a little slower simply by virtue of greater wing area.
The Pacer will cruise faster with those stubby wings.
Zzz wrote:
They both handle great, but I find the Pacer to have a little higher roll rate.
Trim on the Cessna is a tab controlled by a wheel
It's hard to get either one out of balance.
akschu wrote:The 170A doesn't fly as well as the newer cessnas. The rigging is such that there is much more adverse yaw, and I find myself going to slight opposite aileron with rudder in some turns. I suspect the pacer flies a little better.
Resky wrote:If you have potential passengers, I'd let them try out the seats and visiblity, especially in the back seats. You could use any of the pre-back-window Cessnas or I think any of the 4 place fabric Pipers for their evaluation.
akaviator wrote:Resky wrote:If you have potential passengers, I'd let them try out the seats and visiblity, especially in the back seats. You could use any of the pre-back-window Cessnas or I think any of the 4 place fabric Pipers for their evaluation.
And then let them climb in a Sedan.
Mapleflt wrote:Sedan’s are a great option if you can find one, they are a rare bird.
akschu wrote:Zzz wrote:
Performance:
I wouldn't assume that, but perhaps I'm wrong. The cessna has the longer wings, but it also has a much cleaner tail, much cleaner gear, and a single strut. That makes up a lot. Also aluminum wings almost always cruise faster than fabric wings due to deformation.
What do you cruise at? I get right at 100mph with my 170A with a 80/43 prop cut down to a 78.5.
As for performance, both airplanes are two person airplanes if you are counting on any reasonable amount of performance. My 170A with a Horton stol, VG's and climb prop can safely operate with 2 people and 1/2 tank of fuel in 1000ft. That's enough to go play, but it's not great performance compared to other stuff.
Both have a lot of bang for the buck. Having a 2 person airplane you can go play in, for around $35k, burning 7.5gph, is super cheap, right until it needs cyls or fabric or whatever.
