Franklin. [emoji48]Mapleflt wrote:So the preferred is Conti or Lycoming; lets discuss the pros/cons for each
Dirt911 wrote:I’m thinking about this as well, here’s my understanding of the landscape of 170B engine upgrade options. My understanding comes mostly from reading about the topic on the internet, and one longish conversation with Dave Stoots at his hangar, so I am by no means an expert...
1) Del-air O-360 conversion. No web presence. Internet reports that one can call them and they are producing parts for the STC. One member on here reported trouble getting parts for the STC on his time frame, but mostly seems to be a well regarded and reasonably straight forward project. I don’t know what the cost of the STC and kit is.
2) Stoots STCs. He has a few including the lycoming IO-360M1 A & B, IO360 A1A ( which he says is 30 pounds heavier than the M1 series), and the IO-370. Seems like a fairly complete kit, and reasonable project. STC and kit is around 16k, new IO-360M1A is around 45k, new hartzell trailblazer is around 16k, plus maybe 80 hours of shop time. So not a cheap conversion. If you could find a mid time IO-360 M1A (used on diamond da-40) , might save some money.
3) xp-mods continental IO-360 conversion. Fits in the cowl with no modification. Internet reading suggests there’s quite a bit of fabrication and ingenuity involved in the project. There does not seem to be much web presence for the STC seller.
4) Franklin 220 etc. seems like it would make a great airplane. Someone somewhere will think it’d be easy to do, but not for the average guy like me who would need more available support etc.
5) Other. Various bush mods, avcon, Williams STC’s exist, but seem to be mostly abandoned and not supported.
6) The 0-470 conversion. i.e. sell the 170 and buy a 180. Probably the most cost effective solution, until you start deciding whether to convert the 180 to a 0-550 or the various 470 to 520 type things.
Upsides of the conversions in my mind:
1) performance obviously. No question that getting off sooner and climbing faster would be nice
2) constant speed. Not all conversions go with a cs prop, but allows for improving both takeoff and climb as well as cruise
3) resale values are strong. Who am I kidding?
Downsides:
1) no use of auto gas on any of the conversions legally. A big deal if on straight skis (at least in the northeast), or for me at the home field where there’s no 100ll, but etoh-free mogas is available on my way to the airport.
2) most people would like more fuel than the standard 170 tanks. There are solutions, but expensive
He is in Canada, and that conversion is not an easy mod I Canada. We don't have field approvals here, and LSTCs are not cheap.shortfielder wrote:Unless you are REALLY attached to your 170, I think it would be MUCH more cost effective to buy a nice one done. And as for range, I can put you a relatively cheap path using 175 wings. Sell the 170 wings, buy 175 wings and a couple days to switch'em over. Relatively cheap and easy.
shortfielder wrote:Unless you are REALLY attached to your 170, I think it would be MUCH more cost effective to buy a nice one done. And as for range, I can put you a relatively cheap path using 175 wings. Sell the 170 wings, buy 175 wings and a couple days to switch'em over. Relatively cheap and easy. I've had a couple with the 180 lyc/CSP and think they are great for up to 2 and camping.
1. 170 wings don't sell for much at all. You'll probably be negative buying the 175 wings or worse if they don't need any work. If they need work, you'll be really negative. Or, you could list the wings for a ridiculously cheap price and still have them sit in your dad's hangar for five years... Either way, don't bank on getting much of anything out of your old wings.
2. A field approval is needed for the 175 wings (In the US). And we all know how much fun field approvals can be.
3. 175 field approvals bring over the 175's unusable fuel limitations of nine gallons vs your old five. IE all your time, effort and money got you an extra six gallons of gas with 30 pounds of useful load gone. DelAir STC retains the original five gallons unusable so you get ten gallons usable with no useful load penalty. (queue the endless debate on how much fuel is actually usable....)
daedaluscan wrote:I just bought a Delair STC and Kit, never installed. I changed the STC to my airframe with Delair, Chris is very helpful.
It is very complete, down to breakers and wire and terminals. The mount and exhaust are beautiful.
I am looking for an O-360 A1A or D, in Canada as a core or mid time. The USD is SOOOO strong right now.
Prop is an issue, the obvious way to go is a modern composite, but the budget is high. I will probably start off with a Hartzell, hopefully one without the 100hr AD.
Bagarre wrote:shortfielder wrote:Unless you are REALLY attached to your 170, I think it would be MUCH more cost effective to buy a nice one done. And as for range, I can put you a relatively cheap path using 175 wings. Sell the 170 wings, buy 175 wings and a couple days to switch'em over. Relatively cheap and easy. I've had a couple with the 180 lyc/CSP and think they are great for up to 2 and camping.
Having done the 175 wing thing; my vote is for the DelAir extended range STC.
food for thought
