180Marty wrote:I think those are 10 x 10 Alaska Bushwheel wheels. What are those tires?
mtv wrote:Only Dow side is they’re heavy and kinda stiff....but for many surfaces they work fine and they are a lot cheaper than Bushwheel’s.
Bigrenna wrote:mtv wrote:Only Dow side is they’re heavy and kinda stiff....but for many surfaces they work fine and they are a lot cheaper than Bushwheel’s.
I would caution anyone from running this setup. As MTV says, they are freaking heavy... Even shaved. I just installed a set of 8.5x10'a on a customers 185 and even this setup is heavy (42lbs each side.) If memory serves, shaved 29s on AB 10" wheels are 51lbs ea side. GarAero adapters a bit heavier. By contrast, a set of 29" ABW are 38lbs ea.
Another thing that no one really considers is just what kind of detriment 50lbs will have on an old gear leg. To me, this is a bridge too far.
On a 170, the 8.5x10 is a nice setup (for heavy pavement options) provided one is running 180 gear. For early and "lady legs" they are too heavy and will shake the heck out of the bird.
RE: your rebuild... Looking good!!!
mtv wrote:Not sure where you’re getting your info, Greg. Here’s the info on the buffed 29x11x10 tire from Airframes:
Bigrenna wrote:mtv wrote:Not sure where you’re getting your info, Greg. Here’s the info on the buffed 29x11x10 tire from Airframes:
I know you prefer the "read the internet" technique, but I get my info from weighing them when I install them. Perhaps you have found a way to run the tyres w/out any wheels?![]()
As I said, I cant remember exactly the weight of the 29 set-up, but they are indeed heavy. Its been about 18 months since I mounted a set of buffed 29s. Usually I take a pic of the tire on the scale, but for the life of me I cant find the pic...
Real-world weights are not always as promised... So if the tires/tubes are aprox 30lbs, and the AB 10" wheels/rotors are 17-18lbs, and you are at sea level running our heavy air, you are damn near close to 50lbs.
Even at 45lbs thats a ton of tire to hang on an old gear leg.
mtv wrote:Now, those 10 inch wheels do weigh a little more than a 6 inch wheel, but, not THAT much.
As to Internet “data”, I’ve found that Airframes’ information is pretty accurate on items I’ve used. Desser....not so much.
Prosaria wrote:mtv wrote:Now, those 10 inch wheels do weigh a little more than a 6 inch wheel, but, not THAT much.
They are double the weight, 16lbs vs 8lbs.
My Airhawks are 52lbs a side on my scale.
I’ve been flying with them on instead of my bushwheels this winter, they shake out there on the gear leg a LOT more. It was/still is a bit unnerving.
