gbflyer wrote:Wings off seems like a great time to install the kit. Good thinking on the owners part!
G44 wrote:Brian, is that new cowl lighter than the original? If so, by how much?
There is no significant weight difference in the composite cowling and the original Cessna metal cowling. The cowling and individual parts come with STC paperwork. All parts can be sold individually or as a kit. Most, but not all, individual parts will replace existing factory parts. The cowling is ready to bolt on. We supply camlocs to attach upper to lower cowling. The customer supplies hardware to attach cowling to the aircraft.
Brian-StevesAircraft wrote: The following is a cut and past from Selkirk website...There is no significant weight difference in the composite cowling and the original Cessna metal cowling........
However.... This cowling has got to be lighter than the cobbled up POS that was on there to begin with...
hotrod180 wrote:That looks like a sportsman-contour wing extension with a standard-contour Quasar (or similar) tip.
Doesn't Quasar make a sportsman profile tip?
How did you fair the wing leading edge into the wingtip--
is that a store-bought fairing, or something you had to make up?
Can you post a closer up look?
I've considered installing a sportsman leading edge,
but I'd really like to keep my stock wingtips & I'm not sure I'd like how it'd look to fair down to them.
But that set-up actually looks pretty good.
Brian-StevesAircraft wrote:hotrod180 wrote:That looks like a sportsman-contour wing extension with a standard-contour Quasar (or similar) tip.
These tips were on the airplane when the CO bought it... They look factory and not like something that has been modified to fit the Sportsman Cuff... I’ll get more pictures when I put it back together...
Brian
They are probably RMD tips. That it how the sportsman RMD ones look.
