More progress on the 60... should rename the thread...
Have both extensions fitted and modified for the leading edge fit...
This is my replacement leading edge skin fitting right before I riveted it all up...
There are times where I really hate paint... this blue is Omni line metallic.. did not match well at all to the blue already on the airplane.. plus the stuff is so thin, I curtain ran the crap out of it here... I gave up on it and went on to other stuff that needed to be done..
Like installing Door Stewards...
Door Stewards are such an easy mod... all you have to do is fit, drill and cherry max rivet this bracket here in the door frame..
Using the air ram for length you find and pop rivet this bracket onto the door itself...
Install the air ram and test it a couple times...
Then put in the little keeper clips...
Our solution to the crap blue paint... sand, primer seal and paint them white..
Along with the inspection panels for the WingX reinforcement strap access...
And the VG’s that will eventually be glued onto the extension...
While the paint dries, getting an idea where the cargo pod gets located...
Right about here, looking like it’s about to give birth to a Cessna 150 any minute...[emoji23]
Brian
