So we have had the left tank’s in and out at least a dozen times each and are still not quite ready for final install...
Remember that fitting the manufacture was going to send me to plug off the extra hole now in the right tank because of the mixed up installation of the vent valve fitting..? Well, this is what he sent me... this fitting combined with the below cap..
Yes, he expects this flat fitting to seal against a 37 degree cap.. [emoji849].. needless to say, I chucked this piece of crap.. and..
Promptly bought this fuel bulkhead fitting from Summit Auto Racing with a real 37 degree nipple end cap... I ordered this part Wednesday afternoon and had it Thursday with ground shipping.. Summit is on top of their service game..
With the welding wire trick and an extremely long extension with a socket I got the plug installed and have 100% confidence of a leak free port..
On to installing the bits needed for the auxiliary tank bay... these are all of the “Z” stringers fit over the “J” stringers along with the cross pieces fit ready to start putting in the tank bay floor..
And here is Riedar drilling the tank floor into those stringers for eventually installed cherry max flush rivets..
This is the first of many, many times that the auxiliary tank is set in the bay for fitting of parts... here we are fitting the top stringers... these get screwed into place with the tank lid...
As for the “Z” stringers... the kit comes with 6 bottom stringers. 2 left and 2 right top stringers and two forward “support” stringers that are used at the front of the bay... our kit had 1 forward support stringer and 3 right top stringers .. [emoji849] .. just another example of pour quality control.. by the way, I’m am using one of the extra right top stringers for the missing support stringer.. they are bent the same way..
We set the tank lid In Place to mark it for drilling all the attach perimeter screws and the top stringers..
The outer main bay rib needs to be drilled out for the fuel lines, vent line and to clear the original vent tube here...
After trimming it we found out it needed to be cleared not only for the vent tube but also for the other fitting next to it...
Speaking of which, here is the vent tube valve assembly installed into the tank.. you have to make a new “straight” tube in accordance with the STC and it is a royal PITA to install... use a new piece of welding Rod with the end bent into a T configuration.. the tube is put onto the wire, fish the long end of the wire through the tank fitting and use it to pull the vent tube into place.. Same method was used in all the flapper valves I straighten out and the vent tube fittings themselves..
All of the new vent tubes are just cut ends with no beads... let’s fix that..
Super rare Parker beading tools... this is on loan to me because my buddy actually has two of these kits..
With the tube inserted into the correct tool...
It creates this perfect bead on the tube for the hose...
I also beaded the end of the vent tube coming out of the tank once I figured out what length it needed to be..
Back to the main tank for a second... located and installed the gas filler ring with more 10/32 screws than the instructions say to use... they only have you put in 3.. I liked the idea of more to keep it more secure against the bottom of the flange.. this is just showing the drilled holes without the screws in yet.. the screws that you do see are the 1/4 - 20 screws that will eventually be used to install the filler cap flange...
Also installed the fuel sender but first flattened the mounting location with a file because screwing a flat piece against a non flat surface is asking for leaks.. [emoji849].. need I say more here..
Took a bit to make me satisfied it will work...
This is where we stopped for the weekend... the tank needs to be removed again so I can get the inner connect hoses trimmed yet again. the auxiliary tank bay needs more work. And I’m not 100% satisfied with the vent tube system routing.. but, it’s getting there...
Brian
PS
This is the auxiliary tank lid and filler neck... just like an old Ford cap..
With a flat seal..
Brian
