Backcountry Pilot • 1962 Cessna 150TD
1962 Cessna 150TD
46 postsPage 3 of 31, 2, 3
Re: 1962 Cessna 150TD
Happened to catch you on flightaware over DE. Would love to take a look at your 150 if you are coming back thru DE.
62150B offline
Aircraft: 1962 150/160
62150B wrote:Happened to catch you on flightaware over DE. Would love to take a look at your 150 if you are coming back thru DE.
Hey! Sorry, just got back to florida, I've been on the road for the last few days. Would have loved to stop and chat but I was on a tight schedule and was trying my best to avoid all this nasty weather.
Sent from my SM-G981U using Tapatalk
jlacharite offline
Aircraft: Cessna 140 N89476
Cessna 170B N2693D
When I stripped the 180 and now my brothers 170B I found that a hottsy pressure washer was a life saver! Something about the hot water really helped a BUNCH.
I like the SPC-909N stripper. It works really good as long as you put it on heavy the night before, you can walk into the hangar the next morning and sheets of paint will be laying on the floor (you did put a sheet of plastic on the floor right?) Whats left on there hit it with the hottsy. On planes that have had multiple coats of who knows what, you might take a couple applications of the stripper but I have not found anything that it wont take off yet.
Again, I think the key is the hot water. A normal pressure washer using cold water seems to stop the process in its tracks while the hot water just keeps on peeling it off, ESPECIALLY around the rivets. They are pretty spendy to buy, but renting one for a few days is not too bad.
akavidflyer offline
akavidflyer wrote:When I stripped the 180 and now my brothers 170B I found that a hottsy pressure washer was a life saver! Something about the hot water really helped a BUNCH.
Did you get the SPC-909Nstripper at a local store here in Alaska or have to order it? Thanks for the tips.
SkyLarkin offline
Its all good, weather was bad all over so don't blame you trying to squeeze thru. Hope it was a good trip!
62150B offline
Ordered it straight from Canada.
akavidflyer offline
