Backcountry Pilot • 1962 Cessna 150TD
1962 Cessna 150TD
46 posts • Page 1 of 3 • 1, 2, 3
1962 Cessna 150TD
Well, I never posted about it here, but unfortunately I managed to total my old C140. Took off from the grass next to a perfectly good paved runway, found a hidden wet spot in the grass with my left tire, and it pulled me hard left through a fence and into a pond...
Below is the replacement bird. I got my hands on a 1962 Cessna 150B. This particular plane has a Lowe Tailwheel conversion (Baby 180), Desser 8.50x6 tundra tires, and a horton stol kit. The panel has a garmin 660 and a single G5.
The project plans are as follows:
-Add ADSB and ifr navigation with a GNX 375
-Add a second G5 HSI for full IFR capability
-Strip and polish/paint
-be poor
The stripping and painting will be done by myself, so while time consuming, it hopefully won't be very expensive. The panel, while overkill for a Cessna 150, will come in handy for punching through marine layers and as an added insurance policy should I get into inadvertent IMC and need to file. For what it is, and the capabilities it adds, its not too expensive (or at least that's what I keep telling myself)
Below are some pictures of the new bird from ferrying it from California to Florida, the paint scheme plan (grey indicates polished areas), and the new panel plan. ImageImageImageImageImageImageImageImageImageImage
Sent from my SM-G981U using Tapatalk
jlacharite offline
Aircraft: Cessna 140 N89476
Cessna 170B N2693D
Re: 1962 Cessna 150TD
Stuff happens! You didn't mention if you got hurt in the 140. I hope not.
If you have a problem that can be solved with money, then you don't really have a problem, right?
Airplanes can be replaced and it looks like you have a nice little project ahead of you.
Aryana offline
Aircraft: 1955 Cessna 170
Aryana wrote:Stuff happens! You didn't mention if you got hurt in the 140. I hope not.
No injuries other than my pride! This should be a fun little project to keep my hands busy. Nothing mechanically wrong with it, just making it my own
jlacharite offline
Cessna 170B N2693D
Looks a lovely aircraft that
Swap the DI with the TC and put the altimeter where the G5/DI is.
I personally prefer the standard 6 pack.
Bathman offline
Bathman wrote:Looks a lovely aircraft that
Normally, I would also prefer the standard 6 pack. The only reason I moved the HSI up to the altimeter position is because the yoke blocks it in its usual position. I also got my instrument rating in a G1000, so im not overly accustomed to the steam gauge 6 pack for IFR flying as it is.
jlacharite offline
Cessna 170B N2693D
Nice to see you back onboard with a new aircraft! Looking good.
Remember these pictures?
Have you purchased the G5's yet, if not have or did you consider a couple of AV30's ?
The plane already has one g5, and the reason I'm leaning that way over the av30 is because the av30 can not be used as an HSI for approaches. Im looking to get the plane ifr capable
jlacharite offline
Cessna 170B N2693D
Looks like you are planning to do the panel about the same way I did my 150B, but I went basic vfr for mine. Hopefully the pic of mine will help you lay out yours. All the switches are breaker switches also to clean up on the amount of circuit breakers I had to have, I also moved the headset plugs behind the seats to the door post. Love your plane!
62150B offline
Aircraft: 1962 150/160
Some great examples of workmanship, very nice. =D>
I'll be thinking twice about posting my instrument panel upgrade efforts when complete they are pale in comparison. :roll:
8GCBC wrote:Nice to see you back onboard with a new aircraft! Looking good.
Hey! Remember packing the 140 in that box like it was yesterday....
jlacharite offline
Cessna 170B N2693D
Slow progress stripping various parts of the plane. Good news is that the metal underneath is in amazing condition and will polish up beautifully! Since there were other threads asking about paint stripper, I am using Stewart systems ekostrip. Through a little trial and error, I found it is very temperature sensitive and likes warmer temperatures. Also, dont be afraid to lay it on thick. You'll thank yourself later! No harsh fumes and it doesn't burn your skin. ImageImageImageImageImage
jlacharite offline
Cessna 170B N2693D
Your photos are really hurting my neck but I am also really enjoying them. Looks like fun project.
Josef offline
Aircraft: 205A
That's a good looking bird.
I'm betting people on mobile see your photos correctly oriented, but people using desktop browsers see them rotated. One way to fix it is to use our gallery here and copy the BBcode that's supplied, copy and paste it into a post. It will use the photo's meta tag rotation index to correctly display it.
Buy some rope so you never have to tie your airplane down with chains!
Ive heard of issues with ratchet straps but what is wrong with chains?
Josef offline
Aircraft: 205A
Zzz wrote:That's a good looking bird.
On my mobile I see them sideways. But im also on tapatalk, your favorite platform... haha.
Josef wrote:Ive heard of issues with ratchet straps but what is wrong with chains?
Chains have zero give, so when the plane rocks in the wind it comes to a hard jerk at the end of the chain. Very hard on aircraft. I will never use chains to tie down. I use ratchet straps and havent had an issue, just don't suck them down super tight. Enough so there's no slack if the plane rocks and it shouldn't be an issue.
Sorry about the sideways photos everyone! Primarily use tapatalk to access BCP unfortunately... thanks for the kind words on the 150, it's gonna be a lot of work, but it should all pay off in the end
jlacharite offline
Cessna 170B N2693D
Those old 150s make great taildraggers. Enjoy it!
DaveF offline
'54 170B O-360, MT
