2024 aluminium alloy is an aluminium alloy, with copper as the primary alloying element. It is used in applications requiring high strength to weight ratio, as well as good fatigue resistance. It is weldable only through friction welding, and has average machinability. Due to poor corrosion resistance, it is often clad with aluminium or Al-1Zn for protection, although this may reduce the fatigue strength.[1][2] In older systems of terminology, 2XXX series alloys were known as duralumin, and this alloy was named 24ST.
2024 is commonly extruded, and also available in alclad sheet and plate forms. It is not commonly forged (the related 2014 aluminium alloy is, though).[3]
jlacharite wrote:Well, I cant seem to make anything take this paint off of the rivet heads... any other suggestions before I have to go buy a pressure washer?
G44 wrote:jlacharite wrote:Well, I cant seem to make anything take this paint off of the rivet heads... any other suggestions before I have to go buy a pressure washer?
Strip it the best you can, take it to a good paint shop, abandon your plans to polish the airplane and paint it. I’m kinda joking and kinda serious. As you know, it takes an incredible amount of work to take a once painted airplane and turn her into a polished beauty. And you just may tire of the constant polishing and work it takes to keep it that way. A nice well thought out simple classic paint scheme can really look sharp. Just something to consider.
jlacharite wrote:G44 wrote:jlacharite wrote:Well, I cant seem to make anything take this paint off of the rivet heads... any other suggestions before I have to go buy a pressure washer?
haha not the worst advice to be honest..... considering painting the areas i was going to polish with a nice silver flake metallic paint instead. Its going to all depend on how well i can make these rivet heads look. If I cant figure it out and get it looking good, ill just paint it. Luckily, I have a compressor and a paint gun. I can paint semi-decently, just need to finish stripping and see how worn out i am!
Switching between that and aircraft stripper (from Napa autoparts). Each type of stripper has a different effect on different layers and colors of paint. I have no clue what this plane was painted with, but its damn near bullet proofA1Skinner wrote:Are you using the Stewart's stripper?
Thanks. I'm planning to strip my 206 this summer. It only has one coat on it, and I'm quote sure it's not original. Hoping it comes off easy as it's peeling and shiny underneath in a few places.jlacharite wrote:Switching between that and aircraft stripper (from Napa autoparts). Each type of stripper has a different effect on different layers and colors of paint. I have no clue what this plane was painted with, but its damn near bullet proofA1Skinner wrote:Are you using the Stewart's stripper?
Sent from my SM-G981U using Tapatalk
Sounds like you will have a much easier time than I am haha my paint was thick and in great shape. I just didn't like it. It's been a real pain the assA1Skinner wrote:Thanks. I'm planning to strip my 206 this summer. It only has one coat on it, and I'm quote sure it's not original. Hoping it comes off easy as it's peeling and shiny underneath in a few places.jlacharite wrote:Switching between that and aircraft stripper (from Napa autoparts). Each type of stripper has a different effect on different layers and colors of paint. I have no clue what this plane was painted with, but its damn near bullet proofA1Skinner wrote:Are you using the Stewart's stripper?
