Next step will be installing nutplates on the firewall so that can get mounted up, and then hang the engine.
Engine test run went good. Next step is a test flight for the Eagle.
Karmutzen wrote:If you ever want to remove that aft floorboard after the plane is covered, best to make it in two parts.
What tape under the rivets?
A1Skinner wrote:I like to wrap ceconite on the inside of the wing roots before the before the fuselage fabric goes on. Gives the headliner a bit more rigidity in the fuel indicator area. Might be something worth thinking about.
And nice photo shoot!
