Scolopax wrote:Do you have an updated review on the Sportsman STOL installation on your plane now that you have more time flying it Oregon180?
AKclimber wrote:Has anyone else noticed their ASI reading 10-15mph low as compared to the GPS speed?
Prior to the Sportsman the ASI and GPS were in pretty good agreement which was useful in determining wind speed and direction when landing. After sportsman it's less so.
And btw my airflow through the vents is as good as before.
AKclimber wrote:I wasn't sure if others needed to adjust the angle of their pitot tube after sportsman. I have the heated pitot tube. Of course I could have just coincidentally sucked some bugs in there....
ID172inCO wrote:I haven't noticed a change in airflow from the vents on my plane either after installing the Sportsmans STOL. I have a 172K and couldn't be happier with the addition of the kit. My bird has some pretty old seals around the doors and window though. Not sure if this would make much difference, but maybe it does. With the way the plane leaps off the ground at 45 MPH on takeoff, I think I'd still be happy even if my vent didn't work as well.
motoadve wrote:Good news I found the solution, bad news it is expensive.
$450 expensive.
http://www.sportys.com/pilotShop/product/9578
Flow increased like 3 times, plus I can direct it anywhere I want, Costa Rica is hot, to me it is worth it, plus they look real good.
Totally solved my problem.
