I know the 31's use a 6" wheel. does the 35 lights use a 10 or 6" wheel, Thanks in advance.
WilgaBeast wrote:Did you get the axels done or are you throwing those on the stock wheels?
Let me know what you do so I can copy you!!!
ductape wrote:If you land primarily on pavement, bushwheels are a waste of money. The 26" goodyears are a great tire for any surface. I love how many pilots think bigger tires will make them better pilots..... I know some Ol' time Alaskan bush pilots that have never flown with the AK bushwheel and have been into places most pilots can only dream of. I'd also caution buying used tires no matter what type they are or how cheap they are.
WilgaBeast wrote:I think I'd go with the 26's on my Wilga because my home field is paved. They're a hellofalot bigger than what's on there now.
Hottshot wrote:WilgaBeast wrote:I think I'd go with the 26's on my Wilga because my home field is paved. They're a hellofalot bigger than what's on there now.
Ok the 26's would be a bad choice as they will wear faster, less rubber etc.
