I suppose airplanes differ--but for my airplane, the alpha angle is consistent, flaps up or down--I've tested it in all flap configurations, but I initially calibrated it clean, flaps up.
motoadve wrote:This is my second flight with it and Im not trusting it much.
Im finding out that the amount of power changes the number of lights on for the stall.
I need to do more testing and get used to it.
So far I trust more seat of the pants than the AoA, but probably I will start getting to trust it.
Nice one!!motoadve wrote:Im finding out that the amount of power changes the number of lights on for the stall.
RocketRick wrote:I installed it in a 1959 Cessna 180. Was installed in the inspection port just inside the right wing strut.
I never could get it to calibrate after many attempts. Sometimes with just me flying and once with a CFI flying left seat.
I'm removing it. The place that installed it said they'll give me my money back. We'll see.
It may need to be installed farther from the prop. Not sure. I just don't have the inclination to keep trying to calibrate it.
RR
Vick wrote:To revive this topic once more, I swung by the Alpha Systems booth while at OshKosh and spoke with the owner for a while. I asked him what he thought of the contention that his product is not a "true" AoA system and challenged the utility of AoA in light GA aircraft. He had a strong working knowledge of AoA system design and factors in measuring AoA, to include accounting for asymmetric lift/airflow and prop wash. He produced the original study commissioned by the Air Force (in the 70s I think) that assessed the viability of a pressure-differential AoA system and further pointed out that the AoA system on the F-22 is pressure-differential based.
No doubt there was some salemanship at work but I came away impressed with his level of knowledge and confident that he wasn't just selling snake oil. It's well established that you don't "need" an AoA system on a light GA plane, but then you don't "need" a GPS either - these systems just provide higher fidelity information in a convenient format. If nothing else I would say that the charge that this isn't a "real" AoA system is unfounded. I can't comment further because I haven't had the opportunity to fly behind one of these systems, but I'm certainly open to giving it a fair try if the opportunity arises.
iPipehitter599 wrote:Mark's AOA system is a "true" aoa system using differential pressure in order to measure the angle of attack of the wing. Someone posted that it was a pitot-static system, but it is NOT a pitot static system. The AOA probe actually is mounted at approx 70deg angle and there are two ports (upper & lower) which can differentiate the angle of the wing relative to the relative wind - by using differential pressure between the two ports. This is a very good system, good enough that the FAA is allowing his system to be used/installed into certified aircraft without any FAA/PMA certifications - with the caveat that the aoa system does NOT cut into the aircraft's pitot static system or any flight control system (meaning flaps). As long as it is a self contained unit it only requires an A&P logbook entry as a "minor change" (no Fm337 req'd).
mtv wrote:So by that definition, ANY airspeed system is in fact an "Angle of Attack Indicator", since EVERY airspeed system in fact measures ram air pressure and compares it to static pressure.
NoCOpilot wrote:mtv wrote:So by that definition, ANY airspeed system is in fact an "Angle of Attack Indicator", since EVERY airspeed system in fact measures ram air pressure and compares it to static pressure.
There's not a static port on these differential pressure AOA systems, rather two ram ports at some angle to each other. If your AOA system acts like an ASI, or vise versa, then you're not doing it right. I've flown a bit in a Rans with a Dynon Skyview equipped with their optional AOA pitot tube (AOA integrated into the pitot tube, one of the two AOA ram ports is also the pitot port, but same principle as the standalone AOA systems), and they work quite well.
You can question the usefulness of having AOA information in the cockpit, but the operational principle of these devices is sound and totally different than an ASI.
iPipehitter599 wrote:Hey Vick - It's Cabi~. You know me, Vick, I've been flying AOA systems for 24 yrs and I can tell you diffinitively that this is a "real" AOA system. He's even got a unit that's got Bitching-Betty in it too!
