Glidergeek wrote:I do believe that a true AOA indicator measures the angle of the wing vs. the relative wind? Not to say that this gauge doesn't give you pertinent and important information, but if you mounted your ASI on your glare shield and color coded it the same I believe you'd have the same information.
Glidergeek wrote: If you watch Bonanza Man's videos the ASI and the "Lift Indicator" needles correspond accordingly as air speed decreases and stall warning happens at the same speed in all videos.
Glidergeek wrote:BM I do agree that's more info and probably good info. yes load the structure abruptly and increase the angle of attack without pulling the wings off. I'm interested to see if it acts different from the ASI.
Bonanza Man wrote:Glidergeek wrote:BM I do agree that's more info and probably good info. yes load the structure abruptly and increase the angle of attack without pulling the wings off. I'm interested to see if it acts different from the ASI.
I'll play around with the camera mount some more, those videos were pretty poor. Didn't expect that since the videos with the camera mounted on the passenger window were pretty good. So far my experience is the needle is pretty smooth. It doesn't sit and vibrate around. Even with some yawing going on in some of the roughest air I've landed in two weeks ago at Benchmark the needle only moves about a needles width.
Cary wrote:
The Alpha angle is not the stall speed, however. The alpha angle is the slowest airspeed at which full control can be maintained in level flight, so that the needle is at the red/yellow position.
