Still need to rig the control cable to operate the valve. This mod would be a huge pain in the ass if the firewall was in place.
asa wrote:I'm back bitches.
Yesterday was my first day back from Alaska for the season, so time to dig back into the project. I had a lot of momentum going in the spring so hoping I can build that back up. First thing was inventorying all the parts I received while I was gone. A 4 month break was actually nice in that it let lots of long lead items show up, and I also would order things while I was in Alaska if I found good deals.
Right before I left (and of course after I had reinstalled it), I found that my right brake master cylinder shaft had an ever so slight bend in it. It was one of the older ones with a smaller diameter grooved shaft, where bending is apparently common. Only knew to check after Jeremy mentioned it to me - so thanks for that. Ordered a new one from Grove before I left for Alaska so I went ahead and threw it on and re-bled the brakes today. This time the brake bled very easily unlike in the spring. As nice as the new cylinder is, it's tempting to just order another for the left, but I'll refrain.
One exciting thing that showed up over the summer was my EDM900. I'm trying to do all the panel wiring and such over the next month so I want to get everything mounted in the panel soon. Over the summer I did a lot of thinking and decided to move the EDM to the top of the radio stack, and move the Aera660 over to directly in front of the pilot, in portrait mode. Tomorrow I'm hoping to cut the final-ish left side panel so I can get wire lengths and such.
mtv wrote:I like it! Simple, but complete, and logical locations for everything. I hope you did away with the vernier throttle that Maule seems enamored with. Man, I hate those things!
soyAnarchisto wrote:Yeah, I pulled a vernier throttle out of my 180 and replaced it with a very expensive McFarlane vernier assist - best of both worlds but not cheap at all.
Nice work, Asamtv wrote:I like it! Simple, but complete, and logical locations for everything. I hope you did away with the vernier throttle that Maule seems enamored with. Man, I hate those things!
daedaluscan wrote:soyAnarchisto wrote:Yeah, I pulled a vernier throttle out of my 180 and replaced it with a very expensive McFarlane vernier assist - best of both worlds but not cheap at all.
I put a vernier assist in my 170 when I put the 0-360 in. I love that thing.
